Re: Vaccum gauge bouncing ... [Re: herkamer] #1679682
09/29/14 10:13 PM
09/29/14 10:13 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You still haven't told us what happened when you unplugged one wire at a time which will isolate a bad cylinder in case it isn't a carb problem. Just because all the parts are new doesn't mean one couldn't have failed.
Re: Vaccum gauge bouncing ... [Re: stumpy] #1679683
09/29/14 10:37 PM
09/29/14 10:37 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Vaccum gauge bouncing ... [Re: TJP] #1679684
09/29/14 10:54 PM
09/29/14 10:54 PM
IN
ahy Offline
ahy  Offline
IN
I wonder if its possible you got ported vacuum? Sounds silly but wouldn't hurt to check another port... maybe same one as the brake booster.
Re: Vaccum gauge bouncing ... [Re: stumpy] #1679685
09/30/14 04:31 AM
09/30/14 04:31 AM
A Banana Republic near you.
JohnRR Offline OP
JohnRR  Offline OP
No [Edited by Moparts - Family Friendly Site - Keep it clean]'
again , thanks for nothing
Re: Vaccum gauge bouncing ... [Re: ahy] #1679686
09/30/14 04:32 AM
09/30/14 04:32 AM
JohnRR Offline OP
JohnRR  Offline OP
No , it's a holley carb , it was on the base.
Thanks to everyone that was helpful, it'll be a few weeks before I have the time to get back to it.
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679687
09/30/14 06:46 AM
09/30/14 06:46 AM
Right here
HP2 Offline
HP2  Offline
Right here
An useful site for vacuum reading is http://www.secondchancegarage.com/public/186.cfm
If you are running a hot cam things changes. It's impossible to get a steady needle at lower rpm's, so how do you determine what power valve to put in your Holley?
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Vaccum gauge bouncing ... [Re: HP2] #1679688
09/30/14 10:56 AM
09/30/14 10:56 AM
I would think a person would use the lowest (number) of PV available. Cuz you'd wanna stay out of the power circuit until you nail it. OT At WOT if the in hg is at or more than (1) in hg then the carb selection is too small. & either way (CFM) you'd still need a low number to stay out of "power" until you floor it. Back to the problem at hand, Double R we'll be waitin & for your sake it hope I'm wrong about it being a HG
Re: Vaccum gauge bouncing ... [Re: HP2] #1679689
09/30/14 12:05 PM
09/30/14 12:05 PM
scratchnfotraction Offline
thanks, that was indeed an interesting read on the vac readings.
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679690
09/30/14 02:03 PM
09/30/14 02:03 PM
Grand Prairie,Texas
Grand Prairie,Texas
What is your problem?. I have done nothing but try to suggest things to help and you come back with garbage aimed at me. If my advice bugs you so much then put me on ignore.
Re: Vaccum gauge bouncing ... [Re: HP2] #1679691
09/30/14 04:19 PM
09/30/14 04:19 PM
JohnRR Offline OP
JohnRR  Offline OP
Thanks I'll check it out.
As I was trying to fall asleep I remembered something that happened while turning the engine over to inspect the cam while the intake was off , it's either a head gasket or a bent intake valve.
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679692
09/30/14 05:06 PM
09/30/14 05:06 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I was poking you with a stick just for fun, You know your still the coolest right???
Ron
Re: Vaccum gauge bouncing ... [Re: RJS] #1679693
09/30/14 07:03 PM
09/30/14 07:03 PM
JohnRR Offline OP
JohnRR  Offline OP
Ron
I'm far from the coolest ...
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679694
09/30/14 09:46 PM
09/30/14 09:46 PM
I've got a good idea as to what it may be , the problem is in order to change out the offending part to prove that it is bad I'm the one that will have to supply the parts
Double R what are you thinking it is?
Re: Vaccum gauge bouncing ... [Re: RapidRobert] #1679695
10/16/14 06:15 PM
10/16/14 06:15 PM
JohnRR Offline OP
JohnRR  Offline OP
Not that it matters but the spark plug wire test pointed to cylinder #5 according to my friend when he did it but compression check was ok on 3, 5 and 7 ....
Funny part was the broken valve spring was the exh. on cylinder #1
