Re: 360 blocks
[Re: 99yellaR/T]
#1679419
09/28/14 07:09 PM
09/28/14 07:09 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
magnum can use oem roller lifters...and oil thru the pushrods..
LA oil thru the heads..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
Re: 360 blocks
[Re: 70AARcuda]
#1679422
09/28/14 07:25 PM
09/28/14 07:25 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
The first magnum 360 blocks were drilled for LA head oiling. I've had a couple that were like that. I think they were early 1994 blocks. If you cant find a late 80's early 90's LA block you may stumble across an early magnum, just look for the oil hole, if it is there you can use LA heads.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 360 blocks
[Re: 99yellaR/T]
#1679426
09/28/14 10:46 PM
09/28/14 10:46 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
99 year magnum block won't have head oiling, chrysler stop drilling them for head oiling after 95 year blocks.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: 360 blocks
[Re: slammedR/T]
#1679428
09/29/14 12:14 AM
09/29/14 12:14 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
Could run pushrod oiling, provided the oil hole in the rocker will feed the shaft, or rather, feed oil to the shaft. Also, the magnum blocks have a lower deck height. Not by much, but it's enough that if you're shooting for a certain deck clearance, it might require cutting the pistons.
