360 blocks #1679418
09/28/14 07:04 PM
09/28/14 07:04 PM
PA
9
99yellaR/T Offline OP
PA
Any difference between la or a magnum 360 block for a new engine build? Thanks for the help
Re: 360 blocks [Re: 99yellaR/T] #1679419
09/28/14 07:09 PM
09/28/14 07:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
magnum can use oem roller lifters...and oil thru the pushrods..
LA oil thru the heads..
Tony
70 AARCuda Vitamin C
Re: 360 blocks [Re: 70AARcuda] #1679420
09/28/14 07:14 PM
09/28/14 07:14 PM
PA
9
PA
No provision for head oiling with a magnum block? Just trying to come up with what to do with what parts I have available.
Re: 360 blocks [Re: 99yellaR/T] #1679421
09/28/14 07:17 PM
09/28/14 07:17 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
some say the early magnum blocks had it...I dont know..only magnum blocks i have are still in trucks..
Tony
Re: 360 blocks [Re: 70AARcuda] #1679422
09/28/14 07:25 PM
09/28/14 07:25 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
The first magnum 360 blocks were drilled for LA head oiling. I've had a couple that were like that. I think they were early 1994 blocks. If you cant find a late 80's early 90's LA block you may stumble across an early magnum, just look for the oil hole, if it is there you can use LA heads.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 360 blocks [Re: Rapid340] #1679423
09/28/14 07:30 PM
09/28/14 07:30 PM
PA
9
PA
Block I have is a 99 probably not able to use?? Thanks for the help
Re: 360 blocks [Re: 99yellaR/T] #1679424
09/28/14 07:41 PM
09/28/14 07:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Look to see if there is a hole in the deck for oil to the heads...and that hole goes down to cam bearings....cam bearings 2 and 4 supply oil to the heads.
Tony
Re: 360 blocks [Re: 70AARcuda] #1679425
09/28/14 10:41 PM
09/28/14 10:41 PM
PA
9
PA
Will check in the morning.thanks
Re: 360 blocks [Re: 99yellaR/T] #1679426
09/28/14 10:46 PM
09/28/14 10:46 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
99 year magnum block won't have head oiling, chrysler stop drilling them for head oiling after 95 year blocks.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 360 blocks [Re: slammedR/T] #1679427
09/29/14 12:14 AM
09/29/14 12:14 AM
PA
9
PA
Can anything be done or other parts used to make work? Thanks
Re: 360 blocks [Re: slammedR/T] #1679428
09/29/14 12:14 AM
09/29/14 12:14 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Could run pushrod oiling, provided the oil hole in the rocker will feed the shaft, or rather, feed oil to the shaft. Also, the magnum blocks have a lower deck height. Not by much, but it's enough that if you're shooting for a certain deck clearance, it might require cutting the pistons.
Re: 360 blocks [Re: 99yellaR/T] #1679429
09/30/14 09:58 PM
09/30/14 09:58 PM
If you are thinking mag block/LA heads you can T from the oil sender port at the top rear of the block & T & go to the rear of each head & drill in horizontle to the rear pedestal then angle drill down from the top down in the pedestal bolt hole starting several threads down till the passages meet. .080" might be a good start and you can then drill/tap all 5 vertical crank to cam passages & plug them with allenhead setscrews drilled with a 1/16" feed hole which is plenty of lube for cam journals and more than that is a waste of oil volume/psi and OE alot of oil is wasted there especially the one(s) that feed the heads on a LA/B/RB block/heads
