Leaky front runners what to do? #1677744
09/27/14 09:01 PM
09/27/14 09:01 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
When I got this Daytona it had new GY front runners on it. The guy I bought it from said the front wheels needed to be resealed. They are the old Cragar super tricks. So I resealed the wheels. Well they were still going flat so today I used the soapy water. They are leaking through the sidewalls. What is the fix for this? I've heard of using dish soap on the rears. Will the latex fix-a-flat work?
Re: Leaky front runners what to do? [Re: rt66jim] #1677745
09/27/14 09:30 PM
09/27/14 09:30 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Fix a flat is a temp fix and I've even seen it ruin a tire from being left in. It degraded the rubber and made it impossible to balance the tire.
Dish soap on the inside of the side wall can fix a leaking side wall if it's not too bad.
If the tires have been left outside for a long period of time and you can see weather cracking on the side walls then your only option is to replace the tires. I had this issue once and talked to the goodyear rep about it once and was informed that the race tires do not have the UV protection stuff that normal daily driver tires do.
Re: Leaky front runners what to do? [Re: WILD BILL] #1677746
09/27/14 11:39 PM
09/27/14 11:39 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Bill these tires have always been inside a garage. When I bought the car last July they still had the mold [Edited by Moparts - Family Friendly Site - Keep it clean] on them. I have made 2 runs on them. The side walls are not dry cracked. They are seeping air where the serial number plate left it's mark in the side wall.
Re: Leaky front runners what to do? [Re: rt66jim] #1677747
09/27/14 11:58 PM
09/27/14 11:58 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Try the dish soap then.
I admit I've never had to use on front tires but it does work. I've even used it to seal the rear tires on my girls Jrs.
Re: Leaky front runners what to do? [Re: WILD BILL] #1677748
09/28/14 12:26 AM
09/28/14 12:26 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Bill will I have to dismount them? Can I put it in by taking out the valve core and putting it through the valve stem?
Re: Leaky front runners what to do? [Re: rt66jim] #1677749
09/28/14 12:31 AM
09/28/14 12:31 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
You will need to dismount them as you want to coat the entire inside surface with an even coat.
Re: Leaky front runners what to do? [Re: WILD BILL] #1677750
09/28/14 12:54 AM
09/28/14 12:54 AM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Ok Thanks for the help. And welcome back again. Jim
Re: Leaky front runners what to do? [Re: WILD BILL] #1677751
09/28/14 03:55 AM
09/28/14 03:55 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I used fix a flat on my rear tires and it worked great to seal em but now you`ve got me thinking twice about it........... Nice 2 c u again Bill.
Re: Leaky front runners what to do? [Re: rt66jim] #1677752
09/28/14 09:59 AM
09/28/14 09:59 AM
Locomotion Offline
Locomotion  Offline
I'm surprised that nobody mentioned installing tubes, preferably a size smaller than recommended. That does defeat the purpose of having lightweight front tires, but it would be the most effective fix. I use to "paint" the insides of my slicks with dish soap, but haven't needed to with Hoosier radial slicks. Never did the fronts, but I'd be careful. Obviously, age even without sun exposure causes rubber to deteriorate. I had a "brand new" 7 year old trailer tire, stored indoors, peel like a banana after less than 2,000 miles.
(Is there a metal valve stem rule for front wheels/tires?)
Re: Leaky front runners what to do? [Re: Locomotion] #1677753
09/28/14 10:45 AM
09/28/14 10:45 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Not as far as I know but then I've been out of it for a while
I do use metal valves in every wheel that does not have a tube though.
Re: Leaky front runners what to do? [Re: WILD BILL] #1677754
09/28/14 10:51 AM
09/28/14 10:51 AM
Q
Quicktree Offline
Quicktree  Offline
Q
be safe, replace them. not worth the risk
Re: Leaky front runners what to do? [Re: Quicktree] #1677755
09/28/14 12:00 PM
09/28/14 12:00 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
What Tony said. If they were on a garden tractor Id fix them. But for a race car they would be in the trash can. Those tires sound compromised.
Re: Leaky front runners what to do? [Re: Quicktree] #1677756
09/28/14 02:54 PM
09/28/14 02:54 PM
Woodstock, IL
TurboMike Offline
TurboMike  Offline
Woodstock, IL
I had the same problem with my old Crager Super tricks, kept going flat. Turned out to be at the seam,where the two wheel halfs bolt together. Cleaned the old sealer off and put new stuff on..good to go.
Re: Leaky front runners what to do? [Re: TurboMike] #1677757
09/28/14 10:05 PM
09/28/14 10:05 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I did that first.
Re: Leaky front runners what to do? [Re: WILD BILL] #1677758
09/28/14 10:17 PM
09/28/14 10:17 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Yes there is, I was called on it once.
NHRA General Reg. Sec 20 5.1
"Metal, screw-in valve stems mandatory in tubeless
tires, front and rear, on vehicles running 11.99 or quicker"
"Just a Bracket car dressed up like a streetcar"
Re: Leaky front runners what to do? [Re: Just-a-dart] #1677759
09/28/14 10:57 PM
09/28/14 10:57 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Good to know. I guess I never did cause I always use the metal valves anyways
Re: Leaky front runners what to do? [Re: WILD BILL] #1677760
09/29/14 07:14 PM
09/29/14 07:14 PM
dogdays Offline
dogdays  Offline
I have used Seal-All, a thin smear after roughing up the inside surface where the leak is. If you air up the tire a little it'll push the Seal-All into the pinhole until it dries. A thin smear doesn't affect the balance either.
R.
Re: Leaky front runners what to do? [Re: dogdays] #1677761
09/29/14 09:05 PM
09/29/14 09:05 PM
Iowa
coronetville Offline
Iowa
Dont buy front runners, period
