Re: Leaky front runners what to do?
[Re: rt66jim]
#1677747
09/27/14 11:58 PM
09/27/14 11:58 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Try the dish soap then.
I admit I've never had to use on front tires but it does work. I've even used it to seal the rear tires on my girls Jrs.
[Re: rt66jim]
#1677752
09/28/14 09:59 AM
09/28/14 09:59 AM
Posts: 5,894 Florida
Locomotion
I'm surprised that nobody mentioned installing tubes, preferably a size smaller than recommended. That does defeat the purpose of having lightweight front tires, but it would be the most effective fix. I use to "paint" the insides of my slicks with dish soap, but haven't needed to with Hoosier radial slicks. Never did the fronts, but I'd be careful. Obviously, age even without sun exposure causes rubber to deteriorate. I had a "brand new" 7 year old trailer tire, stored indoors, peel like a banana after less than 2,000 miles. (Is there a metal valve stem rule for front wheels/tires?)
[Re: Locomotion]
#1677753
09/28/14 10:45 AM
09/28/14 10:45 AM
WILD BILL
BROOK PARK, OH
Not as far as I know but then I've been out of it for a while
I do use metal valves in every wheel that does not have a tube though.
[Re: Quicktree]
#1677755
09/28/14 12:00 PM
09/28/14 12:00 PM
Posts: 3,396 Pa
Hot 340
Pa
be safe, replace them. not worth the risk
What Tony said. If they were on a garden tractor Id fix them. But for a race car they would be in the trash can. Those tires sound compromised.
[Re: TurboMike]
#1677757
09/28/14 10:05 PM
09/28/14 10:05 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I had the same problem with my old Crager Super tricks, kept going flat. Turned out to be at the seam,where the two wheel halfs bolt together. Cleaned the old sealer off and put new stuff on..good to go.
I did that first.
[Re: Just-a-dart]
#1677759
09/28/14 10:57 PM
09/28/14 10:57 PM
WILD BILL
BROOK PARK, OH
Good to know. I guess I never did cause I always use the metal valves anyways
