Mini Starter ?? #1676838
09/25/14 03:02 PM
09/25/14 03:02 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
If I decide to put a mini starter on my 70 383 RoadRunner which one will work with out a lot of grinding? I looked at a 95 Dakota V-8 starter and it looked like it would work. What has every one used on thiers ?
Re: Mini Starter ?? [Re: okie] #1676839
09/25/14 03:20 PM
09/25/14 03:20 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I use 1997 Dakota same as 95. Mine is a Big Block no grinding necessary.
Re: Mini Starter ?? [Re: okie] #1676840
09/25/14 03:52 PM
09/25/14 03:52 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
tech archive has the best article on it right here
There is a picture of the grinding required, it is so very little that it could be done with a file if you needed to.
Re: Mini Starter ?? [Re: CTD5.9] #1676841
09/25/14 03:56 PM
09/25/14 03:56 PM
an8sec70cuda Offline
All I've ever done was remove the plastic wire connector extension piece. Never had to do any grinding...this is w/ the MP mini starters...same as the late model V8 truck starters.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mini Starter ?? [Re: an8sec70cuda] #1676842
09/25/14 04:01 PM
09/25/14 04:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here.................
Re: Mini Starter ?? [Re: Thumperdart] #1676843
09/25/14 07:45 PM
09/25/14 07:45 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I've only had issues on low deck's, never on a RB
Re: Mini Starter ?? [Re: okie] #1676844
09/25/14 09:00 PM
09/25/14 09:00 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Had to grind a little on a 400.
Re: Mini Starter ?? [Re: Thumperdart] #1676845
09/25/14 10:37 PM
09/25/14 10:37 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Me too. Or in this case, me three...low deck or RB. remove the plastic thingy.
Re: Mini Starter ?? [Re: cudadoug] #1676846
09/25/14 10:42 PM
09/25/14 10:42 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
do these starters sound better than the old school big ones? you know that crappy sound the old ones make?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Mini Starter ?? [Re: Stroker Scamp] #1676847
09/26/14 12:51 AM
09/26/14 12:51 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: Mini Starter ?? [Re: Stroker Scamp] #1676848
09/26/14 01:01 AM
09/26/14 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they sound just like a GM or ford starter...
thats the only starter I have used in 15+ years
Re: Mini Starter ?? [Re: MR_P_BODY] #1676849
09/26/14 09:21 AM
09/26/14 09:21 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
So on my 383 I can figure on doing some grinding, I'm going to pick one up at O"Rielly's 65 for starter and 35 core charge
Re: Mini Starter ?? [Re: Stroker Scamp] #1676850
09/26/14 09:30 AM
09/26/14 09:30 AM
MD-USA
Dodgeguy101 Online content
Dodgeguy101  Online Content
MD-USA
I always liked the distinct sound that those starters had. You always knew it was a mopar starting, didn't have to look. Guess I'm showing my age.
