Mini Starter ?? #1676838
09/25/14 03:02 PM
09/25/14 03:02 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
If I decide to put a mini starter on my 70 383 RoadRunner which one will work with out a lot of grinding? I looked at a 95 Dakota V-8 starter and it looked like it would work. What has every one used on thiers ?
Re: Mini Starter ?? [Re: okie] #1676839
09/25/14 03:20 PM
09/25/14 03:20 PM
WA
JD Dart Offline
JD Dart  Offline
WA
I use 1997 Dakota same as 95. Mine is a Big Block no grinding necessary.
Re: Mini Starter ?? [Re: okie] #1676840
09/25/14 03:52 PM
09/25/14 03:52 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
tech archive has the best article on it right here
There is a picture of the grinding required, it is so very little that it could be done with a file if you needed to.
Re: Mini Starter ?? [Re: CTD5.9] #1676841
09/25/14 03:56 PM
09/25/14 03:56 PM
an8sec70cuda Offline
All I've ever done was remove the plastic wire connector extension piece. Never had to do any grinding...this is w/ the MP mini starters...same as the late model V8 truck starters.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Mini Starter ?? [Re: an8sec70cuda] #1676842
09/25/14 04:01 PM
09/25/14 04:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same here.................
Re: Mini Starter ?? [Re: Thumperdart] #1676843
09/25/14 07:45 PM
09/25/14 07:45 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I've only had issues on low deck's, never on a RB
Re: Mini Starter ?? [Re: okie] #1676844
09/25/14 09:00 PM
09/25/14 09:00 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Had to grind a little on a 400.
Re: Mini Starter ?? [Re: Thumperdart] #1676845
09/25/14 10:37 PM
09/25/14 10:37 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Me too. Or in this case, me three...low deck or RB. remove the plastic thingy.
Re: Mini Starter ?? [Re: cudadoug] #1676846
09/25/14 10:42 PM
09/25/14 10:42 PM
pacific northwest
Stroker Scamp Online content
Stroker Scamp  Online Content
pacific northwest
do these starters sound better than the old school big ones? you know that crappy sound the old ones make?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Mini Starter ?? [Re: Stroker Scamp] #1676847
09/26/14 12:51 AM
09/26/14 12:51 AM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: Mini Starter ?? [Re: Stroker Scamp] #1676848
09/26/14 01:01 AM
09/26/14 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes they sound just like a GM or ford starter...
thats the only starter I have used in 15+ years
Re: Mini Starter ?? [Re: MR_P_BODY] #1676849
09/26/14 09:21 AM
09/26/14 09:21 AM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
So on my 383 I can figure on doing some grinding, I'm going to pick one up at O"Rielly's 65 for starter and 35 core charge
Re: Mini Starter ?? [Re: Stroker Scamp] #1676850
09/26/14 09:30 AM
09/26/14 09:30 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I always liked the distinct sound that those starters had. You always knew it was a mopar starting, didn't have to look. Guess I'm showing my age.
