Re: Trailer towing package on Ram 1500
[Re: 71SCAMP]
#1676466
09/24/14 10:45 AM
09/24/14 10:45 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
There was a pigtail / connector in the glove box, four loose wires on one end for connecting to the controller and a matching plug on the other for attaching to your wiring harness. You might check eBay or Amazon for a new one.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: njmopar]
#1676468
09/24/14 06:20 PM
09/24/14 06:20 PM
Challenger 1
Cincinnati, Ohio
On my '96 the connector (blue if I recall) was taped up near the drivers side kick panel. Wasn't easily seen at first.
That's where it was on our 05 hemi durango and the pigtail was in the glove compartment.
[Re: njmopar]
#1676469
09/24/14 06:25 PM
09/24/14 06:25 PM
Challenger 1
Cincinnati, Ohio
[Re: Challenger 1]
#1676470
09/25/14 01:11 AM
09/25/14 01:11 AM
Posts: 13,187 aZLiViN
J_BODY
aZLiViN
99 Ram.... 05 Durango.... Love ya man!!, but those rigs are so different you might as well said toyota tacoma!
guy on the 96 is a close 2nd.... lots of changes. Unfortunately it clouds my mind so i might not be of any help either as I can't remember when they started the "blue" connector deal... "IF" your truck does have it, it will be attached to the top of the bulkhead connector under the dash on the drivers side, just to the right of the E brake pedal...in between the ebrake and brake pedal.... Hope this helps in some way
