Trailer towing package on Ram 1500 #1676464
09/24/14 10:01 AM
09/24/14 10:01 AM
VIRGINIA
71SCAMP Offline OP
71SCAMP  Offline OP
VIRGINIA
I recently bought a used 1999 Ram 1500 that has what appears to be the facotry towing package. It has the transmission cooler, Class IV hitch and the sideways mounted 7 pin connector that is welded. However I can not find the connector for the trailer brake controller under the dash. There is a white female connector mounted to the drivers side of the wiring harness, but it is much to small for the male connector to trailer brake controller. Local Dodge "parts experts" are all younger than me and can't find info on a 15 y/o truck. Anyone have any suggestions. Thanks for help.
Re: Trailer towing package on Ram 1500 [Re: 71SCAMP] #1676465
09/24/14 10:27 AM
09/24/14 10:27 AM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
With factory towing package there should be a blue connector under the dash with nothing plugged into it. They make pigtails you can plug into it and wire into your brake controller. Do a google search for '99 Dodge trailer brake wire' and an etrailer video comes up and shows what I'm talking about.
Re: Trailer towing package on Ram 1500 [Re: 71SCAMP] #1676466
09/24/14 10:45 AM
09/24/14 10:45 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
There was a pigtail / connector in the glove box, four loose wires on one end for connecting to the controller and a matching plug on the other for attaching to your wiring harness. You might check eBay or Amazon for a new one.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Trailer towing package on Ram 1500 [Re: 71SCAMP] #1676467
09/24/14 04:48 PM
09/24/14 04:48 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
On my '96 the connector (blue if I recall) was taped up near the drivers side kick panel. Wasn't easily seen at first.
Re: Trailer towing package on Ram 1500 [Re: njmopar] #1676468
09/24/14 06:20 PM
09/24/14 06:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's where it was on our 05 hemi durango and the pigtail was in the glove compartment.
Re: Trailer towing package on Ram 1500 [Re: njmopar] #1676469
09/24/14 06:25 PM
09/24/14 06:25 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Trailer towing package on Ram 1500 [Re: Challenger 1] #1676470
09/25/14 01:11 AM
09/25/14 01:11 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
99 Ram.... 05 Durango.... Love ya man!!, but those rigs are so different you might as well said toyota tacoma!
guy on the 96 is a close 2nd.... lots of changes. Unfortunately it clouds my mind so i might not be of any help either as I can't remember when they started the "blue" connector deal... "IF" your truck does have it, it will be attached to the top of the bulkhead connector under the dash on the drivers side, just to the right of the E brake pedal...in between the ebrake and brake pedal.... Hope this helps in some way
Re: Trailer towing package on Ram 1500 [Re: 71SCAMP] #1676471
10/05/14 01:38 AM
10/05/14 01:38 AM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
I have a couple of the pigtail plugins that go to the brake controller if you are interested.
