Tire size #1675951
09/22/14 11:45 PM
09/22/14 11:45 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I currently have a Mickey Thompson L series on the rear of my 72 Cuda and I plan to get some new tires over the winter. 275 60.15 was the plan until this past weekend. A guy that I met has 255 70.15 and I like the look of the slightly narrower tire. His tires run around 10" width verses my almost 11". His tires are 29" tall vs my 28".
Anybody else running this tire size on the rear of your E body.
Also, with a 3.91 rear gear what would a 29" tire roughly bring the effective rear ratio to?
I know from rpm calculators that I would drop about 100 or so rpm with the taller tire.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Tire size [Re: cdstl] #1675952
09/22/14 11:55 PM
09/22/14 11:55 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
My RPM chart shows a 3.91 with a 29 inch tire about the same as a 3.73 with a 28 inch tire. when you talk about width are you thinking tread width or section width? I run 275 on my AAR with 3.91s and I am pleased with them.
Careful, your character's showing!
Re: Tire size [Re: mopar346] #1675953
09/23/14 12:14 AM
09/23/14 12:14 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
The tire size calculator that I used described section width, I thought that was another term for tread width. At any rate, the tires on the orange car are narrower and I kinda like it.
The M/T Ls are supposed to be a 275.60 but they look wider when I compare them to pictures of cars with the metric tire. I DO have rubbing problems with the M/Ts on an 8" rim.
Re: Tire size [Re: cdstl] #1675954
09/23/14 12:46 AM
09/23/14 12:46 AM
mopar346 Offline
mopar346  Offline
Section width is the width of the body of the tire, the bulge if you would, generally it is 1.5-2.0 wider than the thread. I am assuming you have L60s which are wider than the 275s, probably closer to a 295 but I don't know of a 295 60, there is still a 295 65 but it is tall and wide and looks really awesome on 68-69 B bodies. Rim back space would be the key to making them work on an E body. I have a 255 70 15 on a rim on an S-10 chassis I have and I cant really see it on a car, not sure it would look right.
Re: Tire size [Re: mopar346] #1675955
09/23/14 01:41 AM
09/23/14 01:41 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I like your 70 series idea. Most people look at tire width, but the height is what makes or breaks the look.
Re: Tire size [Re: mopar346] #1675956
09/23/14 01:41 AM
09/23/14 01:41 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Well, here ya go...
Re: Tire size [Re: cdstl] #1675957
09/23/14 01:42 AM
09/23/14 01:42 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
Another. He has 245.60s on the front.
Re: Tire size [Re: mopar346] #1675958
09/23/14 01:47 AM
09/23/14 01:47 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I am assuming you have L60s which are wider than the 275s, probably closer to a 295.
OK, that does explain a lot. I had been told that my L60 was a 275. We'll see but I will probably still go with a 275. The guys had those tires laying around and used them on the orange Cuda to get it on the road.
The black Cuda above is mine with the Mickey's.
Re: Tire size [Re: cdstl] #1675959
09/23/14 12:17 PM
09/23/14 12:17 PM
mopar346 Offline
mopar346  Offline
I was trying to come up with the same angle but this is the best I could do.
