Tire size
#1675951
09/22/14 11:45 PM
09/22/14 11:45 PM
Posts: 1,487 STL
cdstl
STL
I currently have a Mickey Thompson L series on the rear of my 72 Cuda and I plan to get some new tires over the winter. 275 60.15 was the plan until this past weekend. A guy that I met has 255 70.15 and I like the look of the slightly narrower tire. His tires run around 10" width verses my almost 11". His tires are 29" tall vs my 28".
Anybody else running this tire size on the rear of your E body.
Also, with a 3.91 rear gear what would a 29" tire roughly bring the effective rear ratio to?
I know from rpm calculators that I would drop about 100 or so rpm with the taller tire.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Tire size
[Re: cdstl]
#1675954
09/23/14 12:46 AM
09/23/14 12:46 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Section width is the width of the body of the tire, the bulge if you would, generally it is 1.5-2.0 wider than the thread. I am assuming you have L60s which are wider than the 275s, probably closer to a 295 but I don't know of a 295 60, there is still a 295 65 but it is tall and wide and looks really awesome on 68-69 B bodies. Rim back space would be the key to making them work on an E body. I have a 255 70 15 on a rim on an S-10 chassis I have and I cant really see it on a car, not sure it would look right.
Careful, your character's showing!
Re: Tire size
[Re: cdstl]
#1675957
09/23/14 01:42 AM
09/23/14 01:42 AM
Posts: 1,487 STL
cdstl
STL
Another. He has 245.60s on the front.
Re: Tire size
[Re: mopar346]
#1675958
09/23/14 01:47 AM
09/23/14 01:47 AM
Posts: 1,487 STL
cdstl
STL
I am assuming you have L60s which are wider than the 275s, probably closer to a 295.
OK, that does explain a lot. I had been told that my L60 was a 275. We'll see but I will probably still go with a 275. The guys had those tires laying around and used them on the orange Cuda to get it on the road.
The black Cuda above is mine with the Mickey's.
Re: Tire size
[Re: cdstl]
#1675959
09/23/14 12:17 PM
09/23/14 12:17 PM
mopar346
I was trying to come up with the same angle but this is the best I could do.
