e-body radiator fan and shroud question #1675576
09/22/14 08:20 AM
09/22/14 08:20 AM
middle of the country
aar1 Offline OP
aar1  Offline OP
1970 big block cuda...... one of the blades on the fan decided to defect......... taking out the shroud and radiatior along the way. Can anyone recommend a good place to get a replacement fan blade and 26" shroud? Stock appearance is the main concern. Thanks.
Re: e-body radiator fan and shroud question [Re: aar1] #1675577
09/22/14 11:51 AM
09/22/14 11:51 AM
O
otter440 Offline
otter440  Offline
O
you can get a schroud right from chrysler
Re: e-body radiator fan and shroud question [Re: aar1] #1675578
09/22/14 11:54 PM
09/22/14 11:54 PM
CA
70-AAR Offline
70-AAR  Offline
CA
I've looked into this also. Only real re-pop that I've come across is at tony's parts.
http://www.tonysparts.com/newproductsE.htm
Half way down the page.
Re: e-body radiator fan and shroud question [Re: aar1] #1675579
09/23/14 04:03 PM
09/23/14 04:03 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
fan itself you'll have to find used.
shroud is still avail thru Mopar pt # 2998326
Re: e-body radiator fan and shroud question [Re: gtx6970] #1675580
10/08/14 11:33 PM
10/08/14 11:33 PM
ontario, canada
plumcrazy704406 Offline
ontario, canada
sorry to change the subject, but how does one come up with part #'s that mother mopar still has in inventory?
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
Re: e-body radiator fan and shroud question [Re: aar1] #1675581
10/09/14 12:49 AM
10/09/14 12:49 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Sorry to hear this. But I have a similar story, same car and big block to boot. But I didn't just lose a blade, the whole fan decided to "defect" Like you the damage was sever, fan, shroud, battery, ground strap.
I hope its not a trend.
Re: e-body radiator fan and shroud question [Re: 67vertman] #1675582
10/09/14 01:58 AM
10/09/14 01:58 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
It has been a problem since the beginning of E Bodies. I saw a blade from a fan go through a 1970 440-6 Cudas Shaker Hood at the Drag Strip during the slicks being heated. These fans are now old and usually have seen some abuse over 40 years.
1971 HEMI E BODY REGISTRY
Re: e-body radiator fan and shroud question [Re: aar1] #1675583
10/09/14 09:05 AM
10/09/14 09:05 AM
Georgia
Steve Bryant Offline
Georgia
Just to echo what the others have said. I got my Mopar Performance P2998326 shroud from Jegs I believe for less than $100 and it fit great.
For the fans, I scan Ebay for them when I need them and pick up a couple and use the best one. I usually blast them with glass to see how the metal looks then coat them and install them.
Re: e-body radiator fan and shroud question [Re: Steve Bryant] #1675584
10/15/14 10:44 PM
10/15/14 10:44 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I just bought the 26 inch shroud from the dealer today. For sure it's not a perfect match to the originals, shape is different and so is the material it's made from. I hope it will fit and function okay though. Wish I hadn't given my originals away a few years ago.
Sheldon
