Water leak 98 Jeep Grand Cherokee #1670835
09/14/14 11:37 AM
09/14/14 11:37 AM
Owego, NY
JBurch Offline OP
JBurch  Offline OP
Owego, NY
Got a persistent water leak, passenger side foot well; been in to the body shop several time for this, last time into the shop I was hoping they got it.........NOT. Was out with my wife; went thru a light rain, the Jeep was parked during the shower (the lot was flat), we went on to some other errands, parked, came out backed out from where we were parked, went up a slight grade and heard water gurgling like a jug in a water cooler and the passenger foot well was soaked again!!
Any body got any ideas??
Thanks,
Jim Burch
Re: Water leak 98 Jeep Grand Cherokee [Re: JBurch] #1670836
09/15/14 02:58 PM
09/15/14 02:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Make sure the drain for the evap box is open.Sounds like water is building up in it and then coming out instead of draining.Usually from the vents is how it gets in.Rocky
Chrysler Firepower
Re: Water leak 98 Jeep Grand Cherokee [Re: therocks] #1670837
09/16/14 10:43 PM
09/16/14 10:43 PM
Owego, NY
JBurch Offline OP
JBurch  Offline OP
Owego, NY
The shop has unplugged/fished out every drain imaginable; last trip in they found a crack in the firewall, thought they might have it that time, then I heard the gurgle.
Any body else have any ideas??
Thanks.
Re: Water leak 98 Jeep Grand Cherokee [Re: JBurch] #1670838
09/16/14 11:28 PM
09/16/14 11:28 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Water could be getting trapped in the cowl area. check down by the lower door hinges for leaves,put the garden hose up by the wipers and see if the water drains out by the lower hinge area. Sun roof? If so check the drain tube. In the picture the regular cowl drains would be in the same area between the lower fender and the cowl side.
Re: Water leak 98 Jeep Grand Cherokee [Re: JBurch] #1670839
09/17/14 01:06 AM
09/17/14 01:06 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
remove seats, remove carpeting, remove A pillar mouldings..... test as required.
Re: Water leak 98 Jeep Grand Cherokee [Re: J_BODY] #1670840
09/18/14 10:14 PM
09/18/14 10:14 PM
Central NC
gch Offline
gch  Offline
Central NC
Just went through this with mine.Found enough leaves and pine straw in the cowl area to build a nest.Open the doors and blow air through there and from the top as much as possible.
I will know if it is fixed next time it rains.
Re: Water leak 98 Jeep Grand Cherokee [Re: gch] #1670841
09/20/14 01:16 AM
09/20/14 01:16 AM
Elk Grove, Calif.
bigblock340power Offline
Elk Grove, Calif.
Re: Water leak 98 Jeep Grand Cherokee [Re: bigblock340power] #1670842
09/20/14 01:43 PM
09/20/14 01:43 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
take wiper off,cowl cover off,shove a vacuum hose down between fender and cowl and it should get all the stuff out
Re: Water leak 98 Jeep Grand Cherokee [Re: bigblock340power] #1670843
10/01/14 09:36 PM
10/01/14 09:36 PM
Central NC
gch Offline
gch  Offline
Central NC
Could be!?
http://www.youtube.com/watch?v=mCogfycZpBw
http://www.youtube.com/watch?v=WJ5xfFVPdjw
Nice find!I will have to try that as cleaning the cowl did not fix mine.
