Water leak 98 Jeep Grand Cherokee
#1670835
09/14/14 11:37 AM
09/14/14 11:37 AM
Posts: 644 Owego, NY
JBurch
Owego, NY
Got a persistent water leak, passenger side foot well; been in to the body shop several time for this, last time into the shop I was hoping they got it.........NOT. Was out with my wife; went thru a light rain, the Jeep was parked during the shower (the lot was flat), we went on to some other errands, parked, came out backed out from where we were parked, went up a slight grade and heard water gurgling like a jug in a water cooler and the passenger foot well was soaked again!!
Any body got any ideas??
Thanks,
Jim Burch
Re: Water leak 98 Jeep Grand Cherokee
[Re: JBurch]
#1670836
09/15/14 02:58 PM
09/15/14 02:58 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
Make sure the drain for the evap box is open.Sounds like water is building up in it and then coming out instead of draining.Usually from the vents is how it gets in.Rocky
Chrysler Firepower
[Re: JBurch]
#1670838
09/16/14 11:28 PM
09/16/14 11:28 PM
Posts: 858 Southeast Pa.
SALEM1912
Southeast Pa.
Water could be getting trapped in the cowl area. check down by the lower door hinges for leaves,put the garden hose up by the wipers and see if the water drains out by the lower hinge area. Sun roof? If so check the drain tube. In the picture the regular cowl drains would be in the same area between the lower fender and the cowl side.
