Removing inner seal in speedometer housing #1670373
09/12/14 07:09 PM
09/12/14 07:09 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
Does anyone have a easy method on removing the inner seal found in the speedometer (TF727) housing they can share? This is the small dime-size seal which the speedometer cable slides into. There's a retaining clip holding the seal in place. Thought I'd ask before I start stabbing it with a sharp object and screwing things up.
Re: Removing inner seal in speedometer housing [Re: cruzin] #1670374
09/12/14 10:12 PM
09/12/14 10:12 PM
rockford illinois
1970A13 Offline
1970A13  Offline
rockford illinois
If you are removing it who cares what happens to it,unless you'r going to reuse it!
Re: Removing inner seal in speedometer housing [Re: 1970A13] #1670375
09/12/14 11:07 PM
09/12/14 11:07 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
The clip just holds it in and can be pushed out easy.
screw driver to remove , thin deep socket to push the new seal and clip back in
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
