Does anyone have a easy method on removing the inner seal found in the speedometer (TF727) housing they can share? This is the small dime-size seal which the speedometer cable slides into. There's a retaining clip holding the seal in place. Thought I'd ask before I start stabbing it with a sharp object and screwing things up.
