Step by step roof rail seal install 68-70 B-Body H/T #1668971
09/08/14 03:13 PM
09/08/14 03:13 PM
Washington State
70_FY1_N96_BEEP Offline OP
Washington State
Purchased the Soffseal seals and would like good step by step instructions. The stainless mounting holes are slotted for future adjustments. Thanks for any help, I can't believe I could not find anything searching.
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: 70_FY1_N96_BEEP] #1668972
09/08/14 05:24 PM
09/08/14 05:24 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
FSM (Factory Service Manual)
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: MOPARMIKE69] #1668973
09/09/14 12:52 AM
09/09/14 12:52 AM
Washington State
Washington State
Service manual has no step by step, just images. And these are aftermarket seals. Nice try.
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: 70_FY1_N96_BEEP] #1668974
09/09/14 02:48 AM
09/09/14 02:48 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Pretty easy install really. Peel out the old one and install the new one. Put some weather strip adhesive at both ends as well as where it makes the sharp bend at the top of the vent window frame. There is also some seam sealer across the joint under the weather strip. Also if you took out the stainless channel piece, you can by repro foam seal or use camper seal available in roll form from any local hardware store. I have use it with good results.
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: 70_FY1_N96_BEEP] #1668975
09/09/14 09:52 AM
09/09/14 09:52 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Nice try? If you have to come on here and ask for a step by step how to install something as simple as these seals then you don't need to be working on a car>. How's that for a nice try!
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: MOPARMIKE69] #1668976
09/09/14 11:10 AM
09/09/14 11:10 AM
Washington State
Washington State
Oh please....why even bother with your generic reply. Car is coming along quite nicely, even with no help from you. Oh, I build aircraft by the way, have a nice day....
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: 70_FY1_N96_BEEP] #1668977
09/09/14 11:20 AM
09/09/14 11:20 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well this explains it. Everything in the aircraft industry has to be done "by the book" and since he can't find the weatherstrip installation instructions in a book, he's stumped !!
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: Stanton] #1668978
09/09/14 05:03 PM
09/09/14 05:03 PM
Washington State
Washington State
Hardly stumped. You may go now. Are you two brothers?
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: 70_FY1_N96_BEEP] #1668979
09/09/14 07:42 PM
09/09/14 07:42 PM
MA
steve70 Offline
steve70  Offline
MA
Do you hang them off string from the ceiling?
1970 Challenger T/A 4 speed
Re: Step by step roof rail seal install 68-70 B-Body H/T [Re: steve70] #1668980
09/09/14 09:35 PM
09/09/14 09:35 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
LMAO !!!!
