Re: Step by step roof rail seal install 68-70 B-Body H/T
[Re: 70_FY1_N96_BEEP]
#1668972
09/08/14 05:24 PM
09/08/14 05:24 PM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
FSM (Factory Service Manual)
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
#1668974
09/09/14 02:48 AM
09/09/14 02:48 AM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
Pretty easy install really. Peel out the old one and install the new one. Put some weather strip adhesive at both ends as well as where it makes the sharp bend at the top of the vent window frame. There is also some seam sealer across the joint under the weather strip. Also if you took out the stainless channel piece, you can by repro foam seal or use camper seal available in roll form from any local hardware store. I have use it with good results.
#1668977
09/09/14 11:20 AM
09/09/14 11:20 AM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Oh, I build aircraft by the way
Well this explains it. Everything in the aircraft industry has to be done "by the book" and since he can't find the weatherstrip installation instructions in a book, he's stumped !!
[Re: steve70]
#1668980
09/09/14 09:35 PM
09/09/14 09:35 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Do you hang them off string from the ceiling?
LMAO !!!!
