Page 1 of 3 1 2 3
"Don't need hi zinc oil since I run a roller" - WRONG! #1666588
09/02/14 02:29 PM
09/02/14 02:29 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Not just on here, but other places, too. Folks say they don't worry about using a performance oil with a high zinc level because they think running roller lifters means that doesn't matter.
Well, I noticed something on Jesel's FAQ page that should change that opinion. They say "We recommend soaking the lifters in mineral based oil prior to installation as well as pre-lubing the engine prior to startup. After initial engine break-in, if you are going to use synthetic based oil, we highly recommend oils containing high zinc content formulated for racing applications. Synthetic oils formulated for street use are not recommended due to a lack of zinc content."
Flat tappet cam or not, if you built it to run hard, I think you better run an oil that can handle the wear and tear.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666589
09/02/14 02:43 PM
09/02/14 02:43 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have been preaching this for years. Flat tappets are not the only high pressure area to worry about. Wrist pins and any valve train component needs a high quality lube.
Keith
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666590
09/02/14 02:52 PM
09/02/14 02:52 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I thought you are rebuilding your engine for the last ten years because you were running no oil
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: sixpackgut] #1666591
09/02/14 02:58 PM
09/02/14 02:58 PM
BradH Offline OP
BradH  Offline OP
First, I think it's only been six, not ten, years.
Second, since I haven't actually touched it in 8 months, I think I can adjust that value down some, too.
Third, I was running good oil when I hurt the engine, but too little of even the good stuff doesn't offset stupidy and the laws of thermal dynamics.
Such is life...
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666592
09/02/14 04:00 PM
09/02/14 04:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Notice the MAGIC word..Synthetic... the old dino
do-do still has some zinc just not a ton like the
PRE cat days... I dont add any zinc to any of my
rollers and run way more pressure than a lot of guys
and never have had a failure
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: MR_P_BODY] #1666593
09/02/14 04:39 PM
09/02/14 04:39 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Rotella T is still a high zinc and phosphorus oil and the Mobil 1 synthetic 20-50 is a high zinc and phosphorus oil also. It says this right on the back of the Mobil 1 bottle and also explains any of their racing oils will have the twin checkered flag symbol letting you know this.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: slammedR/T] #1666594
09/02/14 04:47 PM
09/02/14 04:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I should have said Synthetic street oil... cats dont
like zinc so thats why it was highly reduced(not
eliminated).... all because of cats and emissions
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: MR_P_BODY] #1666595
09/02/14 05:47 PM
09/02/14 05:47 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
I'm pretty sure that Rotella has taken the ZDDP out of their oil also. We build a ton of flat tappet engines and spend a lot of time researching oil and doing what we can to make engines live.
J.C. Childress (434) 665-9541
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: JC Childress] #1666596
09/02/14 05:55 PM
09/02/14 05:55 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
OK so what oil should a roller motor,street/track car use /?????????
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: JC Childress] #1666597
09/02/14 06:27 PM
09/02/14 06:27 PM
gregsdart Offline
gregsdart  Offline
I hear there are additives that work as well or better than zinc. Also that adding zinc to a properly formulated oil can actually hurt the level of protection you would get without it. I hope Leigh chimes in, his engine builder takes care of a lot of circle track racers, and had tried many oils and found one they like that works a lot better than the "known" good oils.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: dynamite] #1666598
09/02/14 06:34 PM
09/02/14 06:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My first couple of questions to the OP would be..
is this a street engine, next would be.. what rpm do
you idle at and third would would be.. are you running
the edm hole in the bottom of the lifter to feed the roller
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: MR_P_BODY] #1666599
09/02/14 06:45 PM
09/02/14 06:45 PM
BradH Offline OP
BradH  Offline OP
- Street driven, mostly to & from the tracks
- 1200 rpm idle, but I don't let it sit there for extended periods of time just waiting for the traffic light to turn green
- rollers have pressure-fed bearing feature
Oils worth considering IMO (but don't blame me if you don't like the price) are JGR "Hot Rod", Amsoil Z-Rod, Brad Penn's "racing" oil, and I'm sure there are others that are capable.
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666600
09/02/14 06:52 PM
09/02/14 06:52 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I know this is a racing forum, and Hyd rollers are not normally found in racing apps, but does a HYD roller get a free pass on the zinc issue? I mean OEM's are making rollers live/work?
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666601
09/02/14 06:56 PM
09/02/14 06:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When I first started running my W-9 engine I was
running synthetic race oil with added zinc but when
I changed to E-85 I switched to dyno do-do mainly
due to I didnt know how much moisture would end up
in the oil... since then I never switched back without
any issues... my previous roller engines always used
dyno do-do and again.. never a failure.. thats 19
years with rollers
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666602
09/02/14 07:02 PM
09/02/14 07:02 PM
tboomer Online work
tboomer  Online Work
Welcome back Brad!
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: jcc] #1666603
09/02/14 07:04 PM
09/02/14 07:04 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
I'd think that's an "It depends" kind of thing. OEMs run hyd rollers on pretty mild cams that have to meet certain service life requirements for a production vehicle. But once somebody swaps out that mild sh!t for something aggressive, then what happens if you still use a modern low zinc street oil?
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: tboomer] #1666604
09/02/14 07:13 PM
09/02/14 07:13 PM
BradH Offline OP
BradH  Offline OP
Welcome back Brad!
Brad's gone... I killed that a$$hole for taking too long to get his junk back together. - Lars Peart (a.k.a. Drummer 1-3/4)
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666605
09/02/14 07:24 PM
09/02/14 07:24 PM
tboomer Online work
tboomer  Online Work
What ever...
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: BradH] #1666606
09/02/14 07:40 PM
09/02/14 07:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Welcome back Brad!
Guess I`m not the only drummer who`s "Bumped his head".........
Re: "Don't need hi zinc oil since I run a roller" - WRONG! [Re: Thumperdart] #1666607
09/02/14 09:55 PM
09/02/14 09:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If it does not say Off Road Race oil only its not good enough for a High $$$ race engine.This is not a smart remark just common sense question.Why would you put Thousands of $$$ in a race or all out street engine and then put cheap oil in it to save a few $$$?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Page 1 of 3 1 2 3
