R/T just quit on me. No spark. Pertronix?? #1664563
08/28/14 12:20 AM
08/28/14 12:20 AM
Wisconsin
wkroncke17 Offline OP
Wisconsin
Took the Coronet for a ride last night for about 1/2 hour.
About 3 blocks from my house it quit on me......nothing.
I am leaning towards thinking it may be something to do with the Pertronix system.
Has anyone had issues with these?
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664564
08/28/14 12:22 AM
08/28/14 12:22 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Does it have spark?
Does the starter spin?
Toss us a wee bit more info and I'm sure the brain trust will kick in.
- Stu Harmon
Re: R/T just quit on me. No spark. Pertronix?? [Re: feets] #1664565
08/28/14 12:35 AM
08/28/14 12:35 AM
Wisconsin
Wisconsin
Does it have spark?
Sorry...starter spins, it has no spark.
I changed ballast resistor, coil, checked all connections.
Thanks for the assist Feets.
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664566
08/28/14 12:41 AM
08/28/14 12:41 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you checked for power at the coil positive post in both the run and start ignition positions?
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664567
08/28/14 01:04 AM
08/28/14 01:04 AM
For a start I'd ohm the P module & see if it has basic continuity and give it a good visual (gap/anything loose or undone). I'm assuming it died while running which'd be on the ign1 (run) circuit & that the ballast was bypassed for the P system. What Stump said if it is still being fed (& likely it is) I'd suspect the P since you have changed out the coil. EDIT I reread & you still have the ballast (& it was replaced). I might be confusing the ballast elimination recommendation with standard MSD install procedure
Re: R/T just quit on me. No spark. Pertronix?? [Re: RapidRobert] #1664568
08/28/14 09:57 AM
08/28/14 09:57 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Try the main harness plugs at the firewalll. I hit a huge bump before & my Charger quit before.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664569
08/28/14 10:00 AM
08/28/14 10:00 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Does it have spark?
Chances are you destroyed the HallCell in the Petronix Module by running it with a ballast resistor
If you should continue to run a Petronix in the future, eliminate the ballast, and make sure to use the correct coil, the Petronix needs to operate at 12 volts, not in diminished capacity
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664570
08/28/14 11:06 AM
08/28/14 11:06 AM
pa.
dan9 Offline
dan9  Offline
pa.
Is it a conversion or a Pertronix distributor? I have a Pertronix distributor and it doesn't use a ballast resistor. You may be able to bypass the resistor to see if it will start.
Re: R/T just quit on me. No spark. Pertronix?? [Re: DAYCLONA] #1664571
08/28/14 11:18 AM
08/28/14 11:18 AM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Mike, guys,
Just a heads up on the ballast resistor - the instructions for the OLDER Pertronix Ignitor modules (Part #1361A & 1381A) state "If your ignition system is equipped with a ballast resistor, do not remove it."
The wiring diagram shows the positive side of the coil going through the BR before going to the Ignitor.
However, the troubleshooting section says if you suffer a low voltage condition, to connect the red Ignitor wire to the the ignition side of the ballast resistor, bypassing it - same as you are saying.
The newer Pertronix Ignitor II may have different instructions.?
Cheers,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: R/T just quit on me. No spark. Pertronix?? [Re: dan9] #1664572
08/28/14 12:17 PM
08/28/14 12:17 PM
Wisconsin
Wisconsin
I do have the original distributor converted, and the original ballast resistor.
So if I eliminate the BR, what do I do with the wires?
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664573
08/28/14 12:20 PM
08/28/14 12:20 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
On mine, I ran a small jumper wire between the terminals of the ballast resister, so I could leave it in place but skip it, as well as using the terminals for the Pertronix wiring.
Darren
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664574
08/28/14 12:20 PM
08/28/14 12:20 PM
North Central USA (MN-WI area)
MuscleMopars Online content
MuscleMopars  Online Content
Take the original ballast resistor and hard wire it from the back side. Then you can leave the wires connected and it will look more original under your hood.
Thanks,
Eric
email eric@musclemopars.com
715-426-HEMI (Shop)
612-669-CARS (Cell and Texts)
Go to my Moparts "Profile" to see my web site
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664575
08/28/14 12:22 PM
08/28/14 12:22 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I have an ignition that doesn't require the ballast. I soldered a jumper across the back of the ballast, shorting it out, so the harness is unmodified.
Treed twice!
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664576
08/28/14 12:22 PM
08/28/14 12:22 PM
Danville, NH
Mopar_Mike Offline
Mopar_Mike  Offline
Danville, NH
IMO.. throw the Pertronix distributor in the trash.. get either a Mopar electronic conversion kit or if low budget get a good used electronic distributor.
RS23L7 4-Speed
Re: R/T just quit on me. No spark. Pertronix?? [Re: Mopar_Mike] #1664577
08/28/14 12:27 PM
08/28/14 12:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
... should he get an ORANGE box too ???
Seriously there have been so many issues with MP distributors and phasing for DECADES , hearing now that even the NEW distributors with the adjustable mechanical advance has phasing issues .
I put my old pertronics set up in a buddies car witha MADE IS USA flame thrower coil , I need to look at the direction and probably switch in a phony ballast, it's running fine right now but I don't wantto burn up the GOOD MADE IN USA parts vs the CCJ they sell now ...
Re: R/T just quit on me. No spark. Pertronix?? [Re: JohnRR] #1664578
08/29/14 01:18 AM
08/29/14 01:18 AM
Wisconsin
Wisconsin
I am going to stick with the Pertronix, i dont want that big ugly orange box under the hood.
I had it wired through the ballast - thank you for the tips on how to jump it.
I also have the wrong coil. The manufacturer reccommends using a 1.5 ohm coil, i have a 0.6 ohm coil.
I'll have the new parts tomorrow, i'll let everyone know how it goes.
Thanks again boys.
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664579
08/29/14 02:51 PM
08/29/14 02:51 PM
Central Ohio
BMChrysler68 Offline
Smarter than the average bear? I think not.
Central Ohio
Thanks again boys.
It just needs 1.5 ohms total to protect the pertronix. If you were running a 0.6 coil with a ballast resistor that makes up the difference, you're fine. I think the 1.5 ohm coil without the ballast resistor is a better scenario, but I don't see how the way you had it would hurt it or cause it not to spark (it would just be a potentially weaker spark). I think you've got a problem somewhere else.
1968 Plymouth Fury III
2dr FT, 383-4v, 4 speed
1972 AMC Ambassador SST wagon
360-4v, automatic
2014 Challenger R/T Classic 6-speed
Re: R/T just quit on me. No spark. Pertronix?? [Re: BMChrysler68] #1664580
08/29/14 03:10 PM
08/29/14 03:10 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
OP make sure your source provides 12 volts to the petronix unit when hot. I had a car that ran well for a time, 30 minutes or so, then once things were good and heat soaked it died. When hot my source had less than 12 volts. Was fine cold.
I want my fair share
Re: R/T just quit on me. No spark. Pertronix?? [Re: SomeCarGuy] #1664581
08/29/14 04:21 PM
08/29/14 04:21 PM
Wisconsin
Wisconsin
I let the car sit overnight, tried it the next day, and still no spark.
Should a volt tester on the + side of the coil give me voltage?
Man I'm not good with this electrical stuff......
Re: R/T just quit on me. No spark. Pertronix?? [Re: wkroncke17] #1664582
08/29/14 04:55 PM
08/29/14 04:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Keep in mind, that during "troubleshooting", if you leave the key/ignition in the run/on mode for more than 20 seconds at a time WITHOUT THE ENGINE RUNNING, you run the risk of damaging the Petronix HallCell
At this point, I say cut your losses, scrap everything, upgrade to an Ignitor II Petronix conversion in a new/rebuilt Chrysler dist., along with the correct Flame Thrower II coil (I'd recommend the epoxy filled unit), and eliminate the ballast resistor, use a copper terminal cap only, no solid core plug wires
Mike
