Page 2 of 3 1 2 3
Re: Roxboro NC street outlaws [Re: Leon441] #1664138
08/28/14 12:00 AM
08/28/14 12:00 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Good luck.
Re: Roxboro NC street outlaws [Re: Leon441] #1664139
08/28/14 01:52 AM
08/28/14 01:52 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
So you are spraying two 36s and about 125-150hp on the plate. With another 150hp in fogger.
I would love to know who considers a .020 pill in a fogger to be 150hp.
150hp on the plate is a lot larger jet than .036. You should know you posted the question on the bullet. Steve gave you a link for his tuneup. Nice try Brad.
Everyone knows a .073-.082 is 150 on a single jet. Two holes half that size together are not going to flow the same. Pie R squared. Just for those following this.
Two 45 are 175 and two 54 are 200. That's a 9 spread and your 9 less with 2 36 jets. That's straight from Steve Johnson's jet chart that I got the link too. Nos jet charts call 20's 150. So tell me Leon what do you think your spraying? How many pph?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Roxboro NC street outlaws [Re: Leon441] #1664140
08/28/14 08:50 AM
08/28/14 08:50 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Good luck. Make Moparts proud!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Roxboro NC street outlaws [Re: OhioMopar] #1664141
08/28/14 08:59 AM
08/28/14 08:59 AM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
The results are not linear when talking about the diameter in a hole. Steve's site showed two charts. One for trashcan solenoid and one for a standard R. This is with his plate.
The proper way to calculate is with your bottle on scales and is rated in lbs per hour.
Power is made with fuel not nitrous. I do not care to share my tune ups with you.
Re: Roxboro NC street outlaws [Re: Leon441] #1664142
08/28/14 10:16 AM
08/28/14 10:16 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Good luck this weekend Leon. If I can get away Sat. I will be glad to help if you need anything.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Roxboro NC street outlaws [Re: Plumb Wired] #1664143
08/28/14 11:01 AM
08/28/14 11:01 AM
Kentuckian
sixpakx Offline
sixpakx  Offline
Kentuckian
good luck, glad to see you got the bottle back
Re: Roxboro NC street outlaws [Re: sixpakx] #1664144
08/28/14 11:08 AM
08/28/14 11:08 AM
ohio
all spooled up Offline
ohio
yes good luck leon is the track 1/8
Re: Roxboro NC street outlaws [Re: sixpakx] #1664145
08/28/14 11:34 AM
08/28/14 11:34 AM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Roxboro NC street outlaws [Re: an8sec70cuda] #1664146
08/28/14 12:07 PM
08/28/14 12:07 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
Yes, its 1/8 mile. Should be neat. Good luck Leon. I know you have some good gas .....lol
J.C. Childress (434) 665-9541
Re: Roxboro NC street outlaws [Re: JC Childress] #1664147
08/28/14 03:28 PM
08/28/14 03:28 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Thanks for having it.
Re: Roxboro NC street outlaws [Re: Leon441] #1664148
08/31/14 10:35 AM
08/31/14 10:35 AM
NC
barracuda man Offline
NC
How did you do leon? I wanted to go but to busy working on motor.
Re: Roxboro NC street outlaws [Re: barracuda man] #1664149
08/31/14 10:40 PM
08/31/14 10:40 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
It was a no time displayed race. I really liked how the time slips showed only the reaction time.
News is we ran well. Car had too much bite. Kept wandering left in the long wheelstands. Then was difficult to drive on top. Went up on tire pressure sat morning which added to the wheel stands. Kept sneaking up on the preload. Went up another quarter lb. for first round after almost loosing the car. Car went left attempted to pedal and car bounced bad deploying the chute. Had the car to beat and double 0'ed the tree.
Changed 4-link today. Will run a lot more pressure now that we have a better idea with the tires. Mid teens in 60ft should be very easy.
Re: Roxboro NC street outlaws [Re: Leon441] #1664150
08/31/14 11:30 PM
08/31/14 11:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like you had a pretty hard day at the office Leon
better luck tomorrow
Re: Roxboro NC street outlaws [Re: MR_P_BODY] #1664151
10/10/14 01:18 PM
10/10/14 01:18 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
Well this is Round two for me.
Farmington,NC Oct. 10&11.
Car should be a lot more manageable. Or at least it has been. We tried my ole PTC converter that posted my best passes in '05 but it is very tight and very hard to stage with this combo. Worked on the carb but had to run ignition timing higher. Called Kenny at PTC and he said he had something better.Don't know yet but it is much easier to stage and he says it will be just as tight in high gear.
Wish me luck
Leon
Re: Roxboro NC street outlaws [Re: Leon441] #1664152
10/10/14 03:42 PM
10/10/14 03:42 PM
BPE Offline
BPE  Offline
Good Luck Leon.
Rod
Re: Roxboro NC street outlaws [Re: Leon441] #1664153
10/10/14 03:47 PM
10/10/14 03:47 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Go get 'em!!
Re: Roxboro NC street outlaws [Re: 80fbody] #1664154
10/10/14 04:17 PM
10/10/14 04:17 PM
ohio
ohio
getrdone leon have fun
Re: Roxboro NC street outlaws [Re: an8sec70cuda] #1664155
10/10/14 07:37 PM
10/10/14 07:37 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Hope it goes better than the race they attempted to do at Darlington back in May...they had about 3 cars show up.
No one around here wants to run on an unprepped surface...including me. Hardly a test of who has the baddest "street car".
Any of the cars around this area that are set up to run on an unprepped surface will not go to the track, let alone run eliminations. They are grudge cars.
I get what they are doing...playing off the TV show and all. That's cool and I hope it does well.
We have KOTS up here, one show in the spring and one in the fall. They have a great turn out, extremely fast cars, and 15k payout to win.
They had to limit the gangster class to 1/8 mile since the cars were seeing the walls, very intense to watch.
Good luck Leon!!
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Roxboro NC street outlaws [Re: DemonDust] #1664156
10/10/14 08:47 PM
10/10/14 08:47 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Good luck Leon!!
No. Only Seniors is 1/8 mile. Jr and gangster still 1/4. A few of my friends have raced it and won it, look for a Duster in next years event, which will only be one weekend.
It's a different scene no doubt but very fun and VERY REAL! Good luck Leon
Re: Roxboro NC street outlaws [Re: SpareParts] #1664157
10/10/14 10:03 PM
10/10/14 10:03 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Yeah, your right my bad. It is the senior class.
Will the duster be at spring or fall?
There was a flat black murdered out road runner there this year at the fall KOTS.
SDG Motorsports
Page 2 of 3 1 2 3
