Re: T/A Steering box
[Re: RACERLEX]
#1662396
08/22/14 11:57 PM
08/22/14 11:57 PM
Posts: 1,102 Ont, Canada
moparo
Ont, Canada
If an AAR or TA are optioned for power steering the only box they got was a fast ratio box marked TA.
Some 71 ebodies were equipped with the same TA box.
performancecarrestorations.com
[Re: Rick_Ehrenberg]
#1662399
08/23/14 12:56 AM
08/23/14 12:56 AM
Posts: 821 NW Ohio
6pkaar
NW Ohio
The T/A box just had the stops moved.
What's special about the case that it needed to have the T/A cast into it? Are the stops cast into the case?
[Re: KARLN]
#1662400
08/23/14 01:12 AM
08/23/14 01:12 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
does that mean that adding the fast ratio pitman arm will essentially give the standard box fast ratio?
Yep.
[Re: autoxcuda]
#1662402
08/23/14 03:24 PM
08/23/14 03:24 PM
Posts: 704 USA
rftroy
USA
Yep.
No.
The factory fast ratio arm will not fit on a standard box. Sector shaft diameter, and splines are different. You will need to go aftermarket to Firm Feel or Hotchkis (there are others) for a longer arm for the standard, small sector shaft box.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1662406
08/23/14 09:44 PM
08/23/14 09:44 PM
autoxcuda
So Cal
Yep.
No.
Robert
I meant from what is available today aftermarket. You can add FF or PST long pitman in large or small spline diameter without master splines to make your steering quick ratio. That is what the original poster has done.
But yes originally the clocking was different on the master splines.
But I thought the T/A boxes were still small 1972 and down B/E/A body diameter???
Are the T/A boxes the larger 60's and up C-body diameter that the B/E/A bodies switched to in 1973?
[Re: floyd]
#1662407
08/23/14 09:47 PM
08/23/14 09:47 PM
autoxcuda
So Cal
What I was trying to say is the "TA" box has the quick ratio option. T/As with the standard power steering option got a regular power steering box (without the raised "TA")
So to clarify more, there were three different steering possibilities on a 70 T/A and 70 AAR ?
[Re: autoxcuda]
#1662408
08/23/14 09:53 PM
08/23/14 09:53 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
My AAR came with a standard manual steering box ..........
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: autoxcuda]
#1662409
08/24/14 03:50 AM
08/24/14 03:50 AM
Posts: 704 USA
rftroy
USA
Yes. Steering gear shaft in T/A box is same large diameter as full size Dodge and Chrysler, but it is a different shaft unique to T/A box. The T/A steering box is not just a standard steering chuck with stops put in, it is heavier duty.
Robert
