T/A Steering box #1662392
08/22/14 11:15 PM
08/22/14 11:15 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
Do ALL AAR's and T/A Challengers have a quick ratio steering box that has T/A stamped on it? Your help is very valuable!
Re: T/A Steering box [Re: RACERLEX] #1662393
08/22/14 11:16 PM
08/22/14 11:16 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
No, optional.
Sheldon
Re: T/A Steering box [Re: RACERLEX] #1662394
08/22/14 11:21 PM
08/22/14 11:21 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
Question #2: Do all AAR's and T/A's have T/A stamped on the steering box?
Re: T/A Steering box [Re: RACERLEX] #1662395
08/22/14 11:37 PM
08/22/14 11:37 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
No..only the Fast Ratio box does...otherwise it is a standard power steering or manual steering box.
Tony
70 AARCuda Vitamin C
Re: T/A Steering box [Re: RACERLEX] #1662396
08/22/14 11:57 PM
08/22/14 11:57 PM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
If an AAR or TA are optioned for power steering the only box they got was a fast ratio box marked TA.
Some 71 ebodies were equipped with the same TA box.
performancecarrestorations.com
Re: T/A Steering box [Re: moparo] #1662397
08/23/14 12:26 AM
08/23/14 12:26 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Actually no OEM fast ratio PS box exists. The T/A box just had the stops moved. Longer pitman sped up the ratio.
Rick
Re: T/A Steering box [Re: Rick_Ehrenberg] #1662398
08/23/14 12:54 AM
08/23/14 12:54 AM
Mississauga, Canada
KARLN Offline
KARLN  Offline
Mississauga, Canada
does that mean that adding the fast ratio pitman arm will essentially give the standard box fast ratio?
B5 Challenger T/A
Re: T/A Steering box [Re: Rick_Ehrenberg] #1662399
08/23/14 12:56 AM
08/23/14 12:56 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
What's special about the case that it needed to have the T/A cast into it? Are the stops cast into the case?
Re: T/A Steering box [Re: KARLN] #1662400
08/23/14 01:12 AM
08/23/14 01:12 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yep.
Re: T/A Steering box [Re: autoxcuda] #1662401
08/23/14 02:34 PM
08/23/14 02:34 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
So....essentially a T/A car COULD have a power steering box that does NOT have T/A written on it? Very important to know today~
Re: T/A Steering box [Re: autoxcuda] #1662402
08/23/14 03:24 PM
08/23/14 03:24 PM
USA
rftroy Offline
rftroy  Offline
USA
Yep.
No.
The factory fast ratio arm will not fit on a standard box. Sector shaft diameter, and splines are different.
You will need to go aftermarket to Firm Feel or Hotchkis (there are others) for a longer arm for the standard, small sector shaft box.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: T/A Steering box [Re: RACERLEX] #1662403
08/23/14 04:27 PM
08/23/14 04:27 PM
MD
floyd Offline
floyd  Offline
MD
T/As could have manual steering, power steering, or quick-ratio power steering. Not all P/S cars got the quick ratio option.
Re: T/A Steering box [Re: floyd] #1662404
08/23/14 06:13 PM
08/23/14 06:13 PM
Clarksville, TN
RACERLEX Offline OP
RACERLEX  Offline OP
Clarksville, TN
Still fishing for the right answer.
Can a T/A car come with a steering box that does NOT have T/A stamped on it?
Re: T/A Steering box [Re: RACERLEX] #1662405
08/23/14 07:10 PM
08/23/14 07:10 PM
MD
floyd Offline
floyd  Offline
MD
What I was trying to say is the "TA" box has the quick ratio option. T/As with the standard power steering option got a regular power steering box (without the raised "TA")
Re: T/A Steering box [Re: rftroy] #1662406
08/23/14 09:44 PM
08/23/14 09:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yep.
No.
Robert
I meant from what is available today aftermarket. You can add FF or PST long pitman in large or small spline diameter without master splines to make your steering quick ratio. That is what the original poster has done.
But yes originally the clocking was different on the master splines.
But I thought the T/A boxes were still small 1972 and down B/E/A body diameter???
Are the T/A boxes the larger 60's and up C-body diameter that the B/E/A bodies switched to in 1973?
Re: T/A Steering box [Re: floyd] #1662407
08/23/14 09:47 PM
08/23/14 09:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
So to clarify more, there were three different steering possibilities on a 70 T/A and 70 AAR ?
Re: T/A Steering box [Re: autoxcuda] #1662408
08/23/14 09:53 PM
08/23/14 09:53 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
My AAR came with a standard manual steering box ..........
Tony
Re: T/A Steering box [Re: autoxcuda] #1662409
08/24/14 03:50 AM
08/24/14 03:50 AM
USA
rftroy Offline
rftroy  Offline
USA
Yes. Steering gear shaft in T/A box is same large diameter as full size Dodge and Chrysler, but it is a different shaft unique to T/A box.
The T/A steering box is not just a standard steering chuck with stops put in, it is heavier duty.
Robert
