carb bolts for an A12 superbee #1659481
08/15/14 08:52 PM
08/15/14 08:52 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
Anyone have any pics of what the correct carb bolts would be for my A12 should look like. Do they have a letter stamp on top and should there be washers? Thanks
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: carb bolts for an A12 superbee [Re: vette1986] #1659482
08/15/14 09:42 PM
08/15/14 09:42 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
no washer,h on the head
i don't have them handy for pics,
i could get some tomarrow if nobody else comes up with some..
Re: carb bolts for an A12 superbee [Re: flypaper] #1659483
08/15/14 11:42 PM
08/15/14 11:42 PM
South Lyon, Michigan
6bblRoadrunner Offline
I believe these are the correct bolts.
Re: carb bolts for an A12 superbee [Re: 6bblRoadrunner] #1659484
08/16/14 10:50 AM
08/16/14 10:50 AM
Wahoo Nebr
Wahoo Nebr
Anyone got a pic of what the top of the intake manifold bolts should look like? Are they different since they are mounting to aluminum not cast iron? Thanks
1969.5 A12 Bee EV2
1971 Charger RT
Re: carb bolts for an A12 superbee [Re: vette1986] #1659485
08/16/14 11:23 AM
08/16/14 11:23 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Intake bolt - 3/8-16 x 1 1/2", 9/16" Hex,
"TR" head marking , Black Phos
Admiration For Multiple Carburetor Vehicles...
Re: carb bolts for an A12 superbee [Re: Stewpar] #1659486
08/16/14 12:12 PM
08/16/14 12:12 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
And, when used on the Edelbrock aluminum manifold, they used washers under the head.
Re: carb bolts for an A12 superbee [Re: 70440+6bbl] #1659487
08/16/14 12:21 PM
08/16/14 12:21 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Ans they weren't lock washers !
Re: carb bolts for an A12 superbee [Re: 62maxwgn] #1659488
08/16/14 12:45 PM
08/16/14 12:45 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
And they weren't lock washers !
washers are a 3/4" outer diameter flat washer and I think are aluminum sixpack manifold only???
Re: carb bolts for an A12 superbee [Re: gtx6970] #1659489
08/16/14 08:10 PM
08/16/14 08:10 PM
western australia
1cuda Offline
1cuda  Offline
western australia
original untouched intake from the "butterbee" on the a12 registry forum-you can see a star washer under that bolt where the return spring bracket is.
all the best
frank.
Re: carb bolts for an A12 superbee [Re: 1cuda] #1659490
08/16/14 08:12 PM
08/16/14 08:12 PM
western australia
1cuda Offline
1cuda  Offline
western australia
the bee we have here has flat washers under the bolts-don`t look at the wrong position of the negative cable-it should be sandwiched between the bracket and the head like previous picture.
all the best
frank.
Re: carb bolts for an A12 superbee [Re: 1cuda] #1659491
08/16/14 11:59 PM
08/16/14 11:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
all the best
frank.
If you look closer you will find that is not a washer,it is the serrations in the top side of the return spring bracket that resemble a washer.
Re: carb bolts for an A12 superbee [Re: 62maxwgn] #1659492
08/17/14 11:53 AM
08/17/14 11:53 AM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
all the best
frank.
You are correct Sir!!
https://www.youtube.com/watch?v=Ji-cT58rgNc
Re: carb bolts for an A12 superbee [Re: Stewpar] #1659493
08/17/14 06:33 PM
08/17/14 06:33 PM
western australia
1cuda Offline
1cuda  Offline
western australia
sorry for that guys-i must have been looking with my elbows again.
all the best
frank.
Re: carb bolts for an A12 superbee [Re: 1cuda] #1659494
08/18/14 09:47 AM
08/18/14 09:47 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
How can you trust the pictures when nobody can even get the throttle return springs correct!
Re: carb bolts for an A12 superbee [Re: Commando1] #1659495
08/18/14 10:54 AM
08/18/14 10:54 AM
western australia
1cuda Offline
1cuda  Offline
western australia
maybe i should have said don`t look at many parts as we are slowly correcting them -such as the whole kickdown linkage setup-the incorrect power booster and master cylinder(now fixed with a midland ross unit-the incorrect wiper motor the wrong engine color and over painted intake etc etc. the main reason i put the picture up was to show the flat washers under the intake bolts which are correct-it isn`t a reference restoration by any means. i thought the question was about intake bolts-yes i wrongly thought there was a star washer under the bracket and after looking at the bee today i do see the serrated bracket. at the end of it all someone might have learned that there are washers under a12 and possibly aluminum intake 6pack cars and someone learned that there is no star washer under the return spring bracket...
all the best
frank
Re: carb bolts for an A12 superbee [Re: 1cuda] #1659496
08/18/14 12:09 PM
08/18/14 12:09 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think they used the flat washers on the intake-to-head bolts to prevent galling from the harder bolts on the AL., thus giving a false torque reading.
Joe
Re: carb bolts for an A12 superbee [Re: gtx6970] #1659497
08/18/14 05:10 PM
08/18/14 05:10 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Correct, no washers in '70 on the cast iron intakes............
