carb bolts for an A12 superbee
#1659481
08/15/14 08:52 PM
08/15/14 08:52 PM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
Anyone have any pics of what the correct carb bolts would be for my A12 should look like. Do they have a letter stamp on top and should there be washers? Thanks
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
Re: carb bolts for an A12 superbee
[Re: 6bblRoadrunner]
#1659484
08/16/14 10:50 AM
08/16/14 10:50 AM
vette1986
Wahoo Nebr
Anyone got a pic of what the top of the intake manifold bolts should look like? Are they different since they are mounting to aluminum not cast iron? Thanks
[Re: Stewpar]
#1659486
08/16/14 12:12 PM
08/16/14 12:12 PM
Posts: 5,268 NY
70440+6bbl
NY
Intake bolt - 3/8-16 x 1 1/2", 9/16" Hex, "TR" head marking , Black Phos
And, when used on the Edelbrock aluminum manifold, they used washers under the head.
[Re: 70440+6bbl]
#1659487
08/16/14 12:21 PM
08/16/14 12:21 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Ans they weren't lock washers !
[Re: 62maxwgn]
#1659488
08/16/14 12:45 PM
08/16/14 12:45 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
And they weren't lock washers !
washers are a 3/4" outer diameter flat washer and I think are aluminum sixpack manifold only???
[Re: 1cuda]
#1659491
08/16/14 11:59 PM
08/16/14 11:59 PM
62maxwgn
Blair County,PA
original untouched intake from the "butterbee" on the a12 registry forum-you can see a star washer under that bolt where the return spring bracket is. all the best frank.
If you look closer you will find that is not a washer,it is the serrations in the top side of the return spring bracket that resemble a washer.
[Re: Commando1]
#1659495
08/18/14 10:54 AM
08/18/14 10:54 AM
Posts: 641 western australia
1cuda
western australia
maybe i should have said don`t look at many parts as we are slowly correcting them -such as the whole kickdown linkage setup-the incorrect power booster and master cylinder(now fixed with a midland ross unit-the incorrect wiper motor the wrong engine color and over painted intake etc etc. the main reason i put the picture up was to show the flat washers under the intake bolts which are correct-it isn`t a reference restoration by any means. i thought the question was about intake bolts-yes i wrongly thought there was a star washer under the bracket and after looking at the bee today i do see the serrated bracket. at the end of it all someone might have learned that there are washers under a12 and possibly aluminum intake 6pack cars and someone learned that there is no star washer under the return spring bracket... all the best frank
