Re: more progress...
[Re: burdar]
#165833
04/22/12 02:15 AM
04/22/12 02:15 AM
Posts: 1,300 Washington
19cuda73
Washington
Darren Its looking great!. Good Job getting that thing on the rubber thats a major milestone!!!. You are doing a fantastic job keep up the good work.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
[Re: burdar]
#165836
05/08/12 01:37 PM
05/08/12 01:37 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#165837
05/08/12 08:19 PM
05/08/12 08:19 PM
19cuda73
Washington
Looks Swweeeeet!!! That thing will be on the road in no time.....
[Re: 19cuda73]
#165838
05/11/12 10:22 AM
05/11/12 10:22 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I got the steering column done last night. The rebuild went well. It's not very complicated. I just disassembled everything and bead blasted the upper parts. I hand sanded the tube since it wouldn't fit in the blast cabinet. I painted most of the pieces with SEM Trim BLack. The ignition key light, upper and lower mounts and the lower steering shaft got painted with gloss black Rustoleum. The turn signal switch was still in good shape so I reused it. The ignition switch had a burned wire on the connector so I replaced it. Before... After... Steering coupler and shaft before... Steering coupler and shaft after...
[Re: burdar]
#165839
05/19/12 01:03 AM
05/19/12 01:03 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#165840
05/29/12 10:50 AM
05/29/12 10:50 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: burdar]
#165844
06/01/12 01:49 AM
06/01/12 01:49 AM
19cuda73
Washington
Looking sharp !! Darren Do you have a date in mind for firing that baby up?
Dennis
[Re: burdar]
#165849
06/04/12 04:55 AM
06/04/12 04:55 AM
19cuda73
Washington
Exhaust is fun. Its the joy of doing all of this while your laying on your back that makes it a fun few days. On your brakes Did you go with Dot 5? or Dot 3 Fluid?
