Hemi intake bolts keep coming loose
#1657096
08/10/14 06:17 PM
08/10/14 06:17 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I need to figure out how to seal & secure the intake fasteners on my BDS intake.Last time I removed the blower,not only were they loose,but oil was pushing up the bolt threads and pooling on top of the intake. I am buying a winch that's on sale at Harbor Freight so I can remove the blower without having 3 or 4 guys come over to help me get it off.The blower has to come off to access the intake bolts. ANY suggestions??????????????????
Re: Hemi intake bolts keep coming loose
[Re: hemi-itis]
#1657097
08/10/14 06:51 PM
08/10/14 06:51 PM
Posts: 1,894 N of Detroit
DaveDudek
N of Detroit
Mr.Gasket intake gaskets? Thick ones?
Dave Dudek 1st Factory Stock legal car in the 10`s!!! [/b] FAST & Factory Stock Rules: www.fastraces.org FAST 69 Hemi RR 9.98@139
[Re: hemi-itis]
#1657099
08/10/14 07:47 PM
08/10/14 07:47 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
permatex thread sealer. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: hemi-itis]
#1657104
08/10/14 08:35 PM
08/10/14 08:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Mark
That's what I used last go round,the white teflon
Teflon is a lubricant you dont want that to hold things tight unless there is friction like a NPT
[Re: 3ddart]
#1657108
08/11/14 12:48 AM
08/11/14 12:48 AM
hemi-itis
Thanks 3D, sorry I missed ya at the tent Harbor Freight has a 2500lb electric winch with remote for $50.00,Then I won't need 4 guys to get the blower off It has to come off to get to the intake bolts
[Re: 80fbody]
#1657114
08/11/14 04:39 PM
08/11/14 04:39 PM
Posts: 1,466 malvern, ohio
3ddart
malvern, ohio
Could be ok, I don't know. My concern would be the blue taking a set too quickly, I mentioned that I retorque numerous times, even waiting overnight sometimes. Also, mine is the only hemi I have built where as this shop has done many + Barton is who he got the info from, so I went with their advise. But as said, might work fine!
[Re: hemi-itis]
#1657115
08/11/14 09:13 PM
08/11/14 09:13 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
That certainly is a lot of oil up in there hemi-itis My recommendation for sealing the bolt threads would be Hylomar Universal Blue. Use sparingly, no need to coat the snot out of them and cause other issues like not getting a proper torque reading. http://www.hylomarsealant.com/Now when it comes to maintaining the bolt torque, gasket materials have a direct effect on clamp load longevity. Soft highly conformable materials tend to loose bolt torque at a faster rate than a dense material. This is mainly due to resisting crush, thereby loading the fastener and maintaining the tension between the two components. Just imagine if you were to put rubber washers behind your lug nuts what might happen The other issue is the make up of the gasket material itself. There are a number of different fibers and chemical binders that are mixed together as a formula to create materials with different properties and specifications. All have their place but apparently the ones you have used should not be placed on your motor. Gasket design can be another factor in aiding long term performance. Using the Hemi as an example. Gaskets that come in the "Blue package" are profiled to match the cylinder head along the bottom profile. Many times this is done to keep or minimize the gasket materials exposure to engine oil and attempt to reduce wicking effects of the gasket material which in turn causes bolt torque loss. Superformance takes a all hands on deck approach to the Hemi intake gasket with a Premium material that was developed to reduce fluid wicking over a long period of time and maintain bolt torque. Adding to that the gasket design has a full skirt across the bottom to help maintain structural integrity in the vulnerable area at the base of the port. The 426 Hemi is a challenging motor on many levels so please don't overlook the importance of having the proper, matching angles top to bottom, front to back or you'll get some good use out of that new hoist
