Hemi intake bolts keep coming loose #1657096
08/10/14 06:17 PM
08/10/14 06:17 PM
Great Neck,LI,new york
hemi-itis Offline OP
I need to figure out how to seal & secure the intake fasteners on my BDS intake.Last time I removed the blower,not only were they loose,but oil was pushing up the bolt threads and pooling on top of the intake.
I am buying a winch that's on sale at Harbor Freight so I can remove the blower without having 3 or 4 guys come over to help me get it off.The blower has to come off to access the intake bolts. ANY suggestions??????????????????
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657097
08/10/14 06:51 PM
08/10/14 06:51 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
Mr.Gasket intake gaskets? Thick ones?
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Hemi intake bolts keep coming loose [Re: DaveDudek] #1657098
08/10/14 07:17 PM
08/10/14 07:17 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I'll see how the O-rings work on mine shortly.
Sheldon
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657099
08/10/14 07:47 PM
08/10/14 07:47 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
permatex thread sealer.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hemi intake bolts keep coming loose [Re: Hemi Allstate] #1657100
08/10/14 07:57 PM
08/10/14 07:57 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Do you have Super Performance intake gaskets? I just bought a couple sets and they torqued down and stayed down after going around them 4-5 times. Dave
Re: Hemi intake bolts keep coming loose [Re: Hemi Allstate] #1657101
08/10/14 08:29 PM
08/10/14 08:29 PM
Mark
That's what I used last go round,the white teflon
Re: Hemi intake bolts keep coming loose [Re: DaveDudek] #1657102
08/10/14 08:31 PM
08/10/14 08:31 PM
I think they were Felpro, CRS
Re: Hemi intake bolts keep coming loose [Re: quickd100] #1657103
08/10/14 08:32 PM
08/10/14 08:32 PM
What are you using on the threads of the bolts??
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657104
08/10/14 08:35 PM
08/10/14 08:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mark
Teflon is a lubricant you dont want that to hold things
tight unless there is friction like a NPT
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657105
08/10/14 08:38 PM
08/10/14 08:38 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
I worried about that with my crossram, but my machinist told me to silicone the upper part of the bolts before putting them in ( not the threads) per info from Barton. I use the right stuff which is a silicone adhesive. I pull the tops off every spring and check them and if the fuel has compromised the silicone I redo the 1s that need it.
Re: Hemi intake bolts keep coming loose [Re: 3ddart] #1657106
08/10/14 08:43 PM
08/10/14 08:43 PM
Mr P, I used that to try and keep the oil from getting pushed up the threads
3D,did you also use a thread locker??
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657107
08/10/14 10:05 PM
08/10/14 10:05 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
No thread locker. Torque the bolts several times before the silicone sets up to get things close. The adhesive property of it will keep the bolts from backing out until fuel compromises the silicone, yet because the silicone gives some you can continue to retorque the bolts several times. I usually redo the torque setting 5 or 6 times letting it set a hour in between, I was told because of it being so low ( inch pounds), as the intake settles it sinks into the heads and needs to be retorqued. The shop glues the gasket to the heads with pilabon construction glue then lightly coats the exposed side with vasoline to help the intake settle in. Also superformance makes really nice intake gasket in .030, .047 and .060. Call Greg and he will take care of you, a super nice guy. I used his intakes a month ago after a couple of carb backfires compromised the cometic skeleton style I had used a couple of years ago. This is what has worked for me and I put about 1500 miles on the car last summer and 500 so far this year. Had it at carlisle last yr and I saw your car at the moparts tent but no one was around. Also know a guy that was loctiteing his torq converter bolts and they kept backing out so he did the silicone trick and that took care of it. He did use locker also on those bolts through. Good luck with it
Re: Hemi intake bolts keep coming loose [Re: 3ddart] #1657108
08/11/14 12:48 AM
08/11/14 12:48 AM
Thanks 3D, sorry I missed ya at the tent
Harbor Freight has a 2500lb electric winch with remote for $50.00,Then I won't need 4 guys to get the blower off
It has to come off to get to the intake bolts
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657109
08/11/14 01:15 AM
08/11/14 01:15 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
It does that if you tighten it after the rtv sets up....Use less of it, or go to a thinner glue. I use a dab of emblem adhesive in each corner. RTV will remain spongey after it cures and you will never get the intake tight.
Re: Hemi intake bolts keep coming loose [Re: Dragula] #1657110
08/11/14 07:46 AM
08/11/14 07:46 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
i always wrap the bolt and especially the washer with silicone (per barton) i go around the intake until there is no more movement from the bolt. never had any issues and 8 yrs later i still check from time to time and never back off or anything.
Re: Hemi intake bolts keep coming loose [Re: prochargedhemi] #1657111
08/11/14 10:52 AM
08/11/14 10:52 AM
I will also ad I have iron heads with an aluminum intake
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657112
08/11/14 01:10 PM
08/11/14 01:10 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
mine are alum hds and alum intake. fuel breaking down the silicone is the only real issue i've seen (and cleaning the holes out when you have to put new gaskets on for some reason) and with the crossram fuel laying in the plenum is a problem but i'm sure your aware of that. also by smearing the silicon on the bolt body it is probably an inch long area in the bolt hole so it takes some time to completely compromise the silicone
Re: Hemi intake bolts keep coming loose [Re: 3ddart] #1657113
08/11/14 01:56 PM
08/11/14 01:56 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
How about blue threadlocker on the threads & silicone above?
Re: Hemi intake bolts keep coming loose [Re: 80fbody] #1657114
08/11/14 04:39 PM
08/11/14 04:39 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
Could be ok, I don't know. My concern would be the blue taking a set too quickly, I mentioned that I retorque numerous times, even waiting overnight sometimes. Also, mine is the only hemi I have built where as this shop has done many + Barton is who he got the info from, so I went with their advise. But as said, might work fine!
Re: Hemi intake bolts keep coming loose [Re: hemi-itis] #1657115
08/11/14 09:13 PM
08/11/14 09:13 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That certainly is a lot of oil up in there hemi-itis
My recommendation for sealing the bolt threads would be Hylomar Universal Blue. Use sparingly, no need to coat the snot out of them and cause other issues like not getting a proper torque reading.
http://www.hylomarsealant.com/
Now when it comes to maintaining the bolt torque, gasket materials have a direct effect on clamp load longevity.
Soft highly conformable materials tend to loose bolt torque at a faster rate than a dense material. This is mainly due to resisting crush, thereby loading the fastener and maintaining the tension between the two components.
Just imagine if you were to put rubber washers behind your lug nuts what might happen
The other issue is the make up of the gasket material itself. There are a number of different fibers and chemical binders that are mixed together as a formula to create materials with different properties and specifications. All have their place but apparently the ones you have used should not be placed on your motor.
Gasket design can be another factor in aiding long term performance.
Using the Hemi as an example. Gaskets that come in the "Blue package" are profiled to match the cylinder head along the bottom profile. Many times this is done to keep or minimize the gasket materials exposure to engine oil and attempt to reduce wicking effects of the gasket material which in turn causes bolt torque loss.
Superformance takes a all hands on deck approach to the Hemi intake gasket with a Premium material that was developed to reduce fluid wicking over a long period of time and maintain bolt torque. Adding to that the gasket design has a full skirt across the bottom to help maintain structural integrity in the vulnerable area at the base of the port.
The 426 Hemi is a challenging motor on many levels so please don't overlook the importance of having the proper, matching angles top to bottom, front to back or you'll get some good use out of that new hoist
