Page 1 of 3 1 2 3
60 ft calculation #1656880
08/09/14 11:05 PM
08/09/14 11:05 PM
illinois
dodgeram1998 Offline OP
illinois
At the track now the car 60 ft is 1.38
440 chrysler 4.1 rears ported Indy Sr 276@ .050 roller
thinkin out loud would I be crazy to think it should run faster than 10.37
Re: 60 ft calculation [Re: dodgeram1998] #1656881
08/09/14 11:13 PM
08/09/14 11:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can take a look at the Wallest site and get a fair idea
http://www.wallaceracing.com/Calculators.htm
Re: 60 ft calculation [Re: dodgeram1998] #1656882
08/09/14 11:21 PM
08/09/14 11:21 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
1.38 is a "typical " n/a high 9 sec lap. You have excellent reason to be optimistic.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 60 ft calculation [Re: dodgeram1998] #1656883
08/09/14 11:24 PM
08/09/14 11:24 PM
Locomotion Offline
Locomotion  Offline
I think you're doing ok. I bracket raced a w-2 360 Challenger @ 2,800 lbs and had high 1.37 - 1.40 60's running 10.20's @ 129 - 131.
If footbraking, fine tuning the squirters and pump cams may help. Tuning for a trans brake would be a bit different which I'm not familiar with.
Stock and Super Stock cars usually have even better 60's for the ET for various reasons, mainly through a lot of work with everything. (Experimenting with cams, converters, gears, shocks, etc.) I've had high 1.40 60' times with 11.20's @ 115-117 weighing 3,540 lbs +, but there are harder leaving cars in Stock with similar ET's & MPH.
Re: 60 ft calculation [Re: B3422W5] #1656884
08/09/14 11:27 PM
08/09/14 11:27 PM
illinois
illinois
Fuel is steady at 6.5. Gonna do some checkin around just seen timing was 42 backed it down to 36 now to make another pass
93 jet pri 103 sec e85 1050
mph is 130 .5
Re: 60 ft calculation [Re: dodgeram1998] #1656885
08/09/14 11:49 PM
08/09/14 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
mph is 130 .5
try it with just a little less timing.. with E-85 you
can try more jet.. keep jetting up till you see the
mph drop then back it down a couple... one thing at
at time
Re: 60 ft calculation [Re: dodgeram1998] #1656886
08/10/14 10:49 AM
08/10/14 10:49 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
What does the car weight? What is your 1/8th mile ET and mph? What stall converter?
There could be a lot of reasons why a 60 ft, mph and ET are not "in line" with each other.
Re: 60 ft calculation [Re: TheOtherDodge] #1656887
08/10/14 12:08 PM
08/10/14 12:08 PM
illinois
illinois
3375 w/driver
103.5 mph @ 1/8
8"flash stall @5100
convertor Is what I suspect? still sorting out as
timing change from , jet change, ,shift point resulted same 1/4 only a .005 et difference
mph stays 130.15
weird eh?
Re: 60 ft calculation [Re: TheOtherDodge] #1656888
08/10/14 12:08 PM
08/10/14 12:08 PM
mi
dirty magnum Offline
mi
weight of car , a lighter car will 60 better
Re: 60 ft calculation [Re: dodgeram1998] #1656889
08/10/14 01:45 PM
08/10/14 01:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
What are the rest of the numbers??
what car cubic inch and shift points MPH gain from 1/8 to 1/4 looks good maybe your short shifting.
Re: 60 ft calculation [Re: dodgeram1998] #1656890
08/10/14 02:03 PM
08/10/14 02:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
With a 446 inch those heads and 276 roller you would probably keep picking up all the way to a 8200 shift point.
and it will want lots of total timing?? How much is timing rolling back when you hit the throttle?
Re: 60 ft calculation [Re: Dodgem] #1656891
08/10/14 10:24 PM
08/10/14 10:24 PM
illinois
illinois
not sure if I understand " how much timing is rolling back when I hit the throttle"
ignition timing is locked out
Re: 60 ft calculation [Re: dodgeram1998] #1656892
08/10/14 11:19 PM
08/10/14 11:19 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
3375 w/driver
103.5 mph @ 1/8
8"flash stall @5100
mph stays 130.15
weird eh?
Your not doing to bad IMO, maybe just a touch slower then the numbers indicate.
1.38/39 is about 10.20
130.5 MPH is about 10.25
Your picking up 26.5 MPH on the back half, so thats very good IMO. Its not your vert. it seems to be working great. Have you ran at more then just one track?
Re: 60 ft calculation [Re: Sport440] #1656893
08/10/14 11:41 PM
08/10/14 11:41 PM
Portage,michigan
Portage,michigan
I disagree that 1.38 equates to 10.20.. .... Way to many variables involved to make that statement.
My old car(3350 race weight) most often went 1.36-38 60 foots on 9 sec passes.
As another example I know 340 Ricks gen3 Challenger goes mid/ high 1.3xx while running 9.60's.
Compression, suspension, weight, and other factors contribute as well.
At 3375 pounds, that 1.38 would absolutely not hinder a much better time slip.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 60 ft calculation [Re: dodgeram1998] #1656894
08/11/14 12:00 AM
08/11/14 12:00 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
You may have the timing set at 38 but when you hit the throttle it may roll back as slack comes out of things 2 to 7 degrees and sometimes more.
So you have to watch as you whack throttle to see what it does.
Re: 60 ft calculation [Re: Sport440] #1656895
08/11/14 12:33 AM
08/11/14 12:33 AM
illinois
illinois
first outing with this combo
Re: 60 ft calculation [Re: Dodgem] #1656896
08/11/14 12:42 AM
08/11/14 12:42 AM
illinois
illinois
I will recheck the timing for good measure (gear drive). I have only whacked the throttle up to say 2000 rpm in setting the timing.
Whats strange is the car saw no time slip change with short shifting at 6700 or 6000, jet change, only timing change from 42 down to 36 netted me a minus .5 mile an hour
Gonna be looking at the burn at the ground strap on the plugs next if there hot enough
Re: 60 ft calculation [Re: dodgeram1998] #1656897
08/11/14 12:46 AM
08/11/14 12:46 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
My junk runs 130 mph at the stripe - and I can only dream of 1.3X 60's at 4200#.
I'm running 10.50s. LOL
Good luck with it - I'm sure you'll get that ET wittled down in no time!
Re: 60 ft calculation [Re: dodgeram1998] #1656898
08/12/14 01:46 PM
08/12/14 01:46 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I set my timing at 43 but if you whack the throttle good you can see it backs up to 39 ish.
You need lots of advance on that cam and lots of rpms I ran a 272/282 .700 lift 110 LSA in my 452 installed at 100 and it loved 7600 to 7800 shifts.
Same combo now with 255/263 .700 lift 108 LSA installed at 103 runs same times with 7200 shifts.
Re: 60 ft calculation [Re: dodgeram1998] #1656899
08/12/14 06:04 PM
08/12/14 06:04 PM
illinois
illinois
Last pass of the nite, just pass the 1/8 I think i saw my fuel pressure dropped to 3-4 pounds . Oops fuel delivery I am suspicious issues found.cell non vented,
return line pressure isolated today discovered is registering 3 pound i guess pretty bad for a mallory 4309 regulAtor and hoping to get rid of some fittings in return line.. install the fuel return on the side of the fuel cell to rid restrictions if its compliant with the rule books??
My secondary power valve was installed not blocked off
And my 02 sensor went dead on me as I got to the track lol
will fix what I have found to be suspect
Conan cOnvertor tech thinks my convertor works good up to this point unless proven wrong with logged data
thanks guys
Page 1 of 3 1 2 3
