Head gaskets didn't seal #1656277
08/08/14 12:00 AM
08/08/14 12:00 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Guys,
My rebuilt, 60-over, 440 runs great except for the fact that passenger side head gasket (8519 PT) apparently didn't seal. I tore it apart tonight and it was leaking coolant into the No. 4 cylinder, but the gasket wasn't blown. The motor has Eddy aluminum heads and only 9:1 compression.
Before I took the heads off, I checked the torque on the bolts, I didn't get any movement at 70 foot lbs. However, when I undid the bolts, they seemed to undo at varying degrees of effort, and I wonder if that was problem.
Anyway, I am ordering new gaskets and am going to try again. Does anyone have any advice? I have successfully changed head gaskets before without any problems, I am not sure what went wrong.
Thanks.
Greg
Re: Head gaskets didn't seal [Re: GregY] #1656278
08/08/14 12:03 AM
08/08/14 12:03 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Maybe some were overtorqued, who assembled it? Did you check for overhang into the combustion chamber?
Re: Head gaskets didn't seal [Re: GregY] #1656279
08/08/14 12:11 AM
08/08/14 12:11 AM
Several things we need more information on, what condition(rough, semi rough or smooth) are the surfaces on the head and block on that side? Are the head and block straight with no warpage? When you say the gasket is not blown, how about cracks in the head or cyclinder? Good luck, let us know what you find out
Re: Head gaskets didn't seal [Re: GTX MATT] #1656280
08/08/14 12:12 AM
08/08/14 12:12 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
I assembled it. I tried to be careful and lube the bolts/shoulders/washers. I did not check for overhang.
I used some FelPro 1009's once that apparently overhung and blew.
I didn't see any evidence this one was blown, it appears it just didn't seal. Or the block is cracked, I guess could be the other option, but I had it checked first.
Hopefully I just screwed up and if I am more careful this time it will be okay.
Re: Head gaskets didn't seal [Re: Cab_Burge] #1656281
08/08/14 12:18 AM
08/08/14 12:18 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
The block was decked and the heads are brand new OOTB Eddy. I can double check those now that the motor is apart. I would hope the heads aren't cracked.
I guess I am not sure whether the surfaces are rough or smooth. The machine shop knew I was putting on aluminum heads.
Re: Head gaskets didn't seal [Re: GregY] #1656282
08/08/14 12:28 AM
08/08/14 12:28 AM
I use my finger nails, when there long enough, to judge the finish on the heads and blocks, if I feel the serations from the cutter on either the block or heads it is to rough for me I have had new Cometics MLS head gaskets on a new Hemi block leak before I found out they(Cometic MLS gaskets) need a RA finish of 50 or smoother to seal IHTHs Check for cracks real good
Re: Head gaskets didn't seal [Re: Cab_Burge] #1656283
08/08/14 12:32 AM
08/08/14 12:32 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Head bolts bottomed out?
Sheldon
Re: Head gaskets didn't seal [Re: GregY] #1656284
08/08/14 12:37 AM
08/08/14 12:37 AM
Chase the block threads with a thread chaser tap & blow em out clean with the nozzle that goes all the way in to the bottom of blind holes. I dip bolt threads in 30wt eng oil then blow em off with shop air. As you know torque in multiple stages. Good visual inspection of the new gasket. yes check the head deck flatness. I'm assuming those Felpro's are Ok with alum heads, not sure but I've heard Cometics are a good choice for that app (iron block/alum heads) but wait for someone to elaborate further. EDIT Reuse (good thread visual tho)
Re: Head gaskets didn't seal [Re: RapidRobert] #1656285
08/08/14 12:40 AM
08/08/14 12:40 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Would you guys reuse the head bolts? Or buy new ones?
Re: Head gaskets didn't seal [Re: GregY] #1656286
08/08/14 12:44 AM
08/08/14 12:44 AM
RUNCHARGER Offline
RUNCHARGER  Offline
I re-use them in a stock application but I'm not sure if they are recommended with the Edelbrock heads.
I didn't mean to interrupt Cab but it just struck me when you said it took different amounts of force to back the bolts out.
Sheldon
Re: Head gaskets didn't seal [Re: GregY] #1656287
08/08/14 03:51 AM
08/08/14 03:51 AM
SE PA
Yellow Fever Offline
SE PA
ARP's? I always bought the recommended head bolts with any aluminum heads. Check for stretch and reuse if ok.
Re: Head gaskets didn't seal [Re: Yellow Fever] #1656288
08/08/14 08:23 AM
08/08/14 08:23 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
They were the recommended Edelbrock head bolts.
At this point I will probably just pony up and buy new ones. What's another $100? Once my car makes me broke and insane, the $100 will be the least of my worries.
Re: Head gaskets didn't seal [Re: GregY] #1656289
08/08/14 10:40 AM
08/08/14 10:40 AM
I like this guy
Re: Head gaskets didn't seal [Re: GregY] #1656290
08/08/14 10:43 AM
08/08/14 10:43 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Those are the cheaper gaskets.Try a set of FelPro Marine gaskets.I use them with Stealth heads and no problems.I used ARP bolts on mine.Just make sure to torque in 3 stages and use lube.Rocky
Chrysler Firepower
Re: Head gaskets didn't seal [Re: RUNCHARGER] #1656291
08/08/14 11:20 AM
08/08/14 11:20 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sheldon
or the dowel pins ?
A friend .. RIP ... Had a similar issue , but it wasn't the head bolts bottoming , it was the threads in the block were screwed up and gave a FALSE torque reading , 2 sets of gaskets later ... 20 plus qts of oil and 2 trips to a big name hemi builder in Pa. that didn't do it right the first 2 times ... I told him it should have head studs instead of bolts on a race engine making 800 pls HP and Alum heads, switched to head studs and problem solved ...
I'm not suggesting that this build needs studs ...
Re: Head gaskets didn't seal [Re: JohnRR] #1656292
08/08/14 11:40 AM
08/08/14 11:40 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Sheldon
or the dowel pins ?
Agreed...I've seen head gasket problems (blow outs) from having milled heads, and decked blocks an the assembler didn't dry fit (no gasket) the head to see if the dowels were too long....sometimes it's the simplest of things that cause major issues, always double check everything
mike
Re: Head gaskets didn't seal [Re: DAYCLONA] #1656293
08/08/14 12:35 PM
08/08/14 12:35 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Yup, very possible.
Sheldon
Re: Head gaskets didn't seal [Re: RUNCHARGER] #1656294
08/08/14 02:30 PM
08/08/14 02:30 PM
dogdays Offline
dogdays  Offline
These aren't torque-to-yield bolts. Reuse'em. Period.
Replacing them is just stupid. Don't be that guy.
It is SO EASY for someone else to tell you to spend money unnecessarily, after all they don't feel your pain.
ANY USA-made Grade 8 bolt can stand hundreds, if not thousands of torquings to less than yield stress without losing its strength or stretching. That's why we use steel for bolts.
Do you feel that I'm yelling? I am. The amount of superstition and needless replacement of parts on this board is enough to drive me nuts.
My mercedes engine has torque-to-yield rod bolts. So what does the factory service manual say about replacement? It says reuse them until the necked down area is less than a specified dimension. These bolts are torqued past their yield point (they permanently stretch) during assembly, and it would be easy for M-B to say replace them, but they know that's not necessary. I measured them, they were well above the spec, reused them and took the engine to redline the first time out. 6500 rpm with a reused torque-to-yield rod bolt? No sweat. That's what mechanical engineers are for.
R.
Re: Head gaskets didn't seal [Re: GregY] #1656295
08/08/14 03:12 PM
08/08/14 03:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
When exactly did this happen? Was it with these heads and after the machining?
How did you discover that water was getting into a cylinder?
Re: Head gaskets didn't seal [Re: BSB67] #1656296
08/08/14 08:20 PM
08/08/14 08:20 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
No this was in the motors old days. All the stuff (heads/machine work) is new. Motor was broken in and dyno tested, the shop didn't report any problems. Started spewing coolant as soon as I got it installed (which was like a year after I got it back, I am a slow worker) and started it.
The water got in the oil too, not just the combustion chamber. Does that offer any clues as to what is happening?
Also, I am not going to buy new head bolts, I am going to check the bolt and dowel lenghts, and I am going to buy better gaskets, probably the recommended Edelbrock 7325.
Maybe I am already insane, and that is causing my car problems, not the other way around!
Thanks for all the help, it is really appreciated.
Greg
