Head gaskets didn't seal
#1656277
08/08/14 12:00 AM
08/08/14 12:00 AM
Posts: 1,194 Rochester, New York
GregY
Rochester, New York
Guys,
My rebuilt, 60-over, 440 runs great except for the fact that passenger side head gasket (8519 PT) apparently didn't seal. I tore it apart tonight and it was leaking coolant into the No. 4 cylinder, but the gasket wasn't blown. The motor has Eddy aluminum heads and only 9:1 compression.
Before I took the heads off, I checked the torque on the bolts, I didn't get any movement at 70 foot lbs. However, when I undid the bolts, they seemed to undo at varying degrees of effort, and I wonder if that was problem.
Anyway, I am ordering new gaskets and am going to try again. Does anyone have any advice? I have successfully changed head gaskets before without any problems, I am not sure what went wrong.
Thanks.
Greg
Re: Head gaskets didn't seal
[Re: GregY]
#1656278
08/08/14 12:03 AM
08/08/14 12:03 AM
Posts: 5,161 CT
GTX MATT
CT
Maybe some were overtorqued, who assembled it? Did you check for overhang into the combustion chamber?
[Re: Cab_Burge]
#1656281
08/08/14 12:18 AM
08/08/14 12:18 AM
GregY
Rochester, New York
The block was decked and the heads are brand new OOTB Eddy. I can double check those now that the motor is apart. I would hope the heads aren't cracked.
I guess I am not sure whether the surfaces are rough or smooth. The machine shop knew I was putting on aluminum heads.
[Re: GregY]
#1656284
08/08/14 12:37 AM
08/08/14 12:37 AM
RapidRobert
Chase the block threads with a thread chaser tap & blow em out clean with the nozzle that goes all the way in to the bottom of blind holes. I dip bolt threads in 30wt eng oil then blow em off with shop air. As you know torque in multiple stages. Good visual inspection of the new gasket. yes check the head deck flatness. I'm assuming those Felpro's are Ok with alum heads, not sure but I've heard Cometics are a good choice for that app (iron block/alum heads) but wait for someone to elaborate further. EDIT Reuse (good thread visual tho)
[Re: GregY]
#1656287
08/08/14 03:51 AM
08/08/14 03:51 AM
Posts: 1,083 SE PA
Yellow Fever
SE PA
Would you guys reuse the head bolts? Or buy new ones?
ARP's? I always bought the recommended head bolts with any aluminum heads. Check for stretch and reuse if ok.
[Re: GregY]
#1656290
08/08/14 10:43 AM
08/08/14 10:43 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Those are the cheaper gaskets.Try a set of FelPro Marine gaskets.I use them with Stealth heads and no problems.I used ARP bolts on mine.Just make sure to torque in 3 stages and use lube.Rocky
Chrysler Firepower
[Re: RUNCHARGER]
#1656291
08/08/14 11:20 AM
08/08/14 11:20 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Head bolts bottomed out?
Sheldon
or the dowel pins ?
A friend .. RIP ... Had a similar issue , but it wasn't the head bolts bottoming , it was the threads in the block were screwed up and gave a FALSE torque reading , 2 sets of gaskets later ... 20 plus qts of oil and 2 trips to a big name hemi builder in Pa. that didn't do it right the first 2 times ... I told him it should have head studs instead of bolts on a race engine making 800 pls HP and Alum heads, switched to head studs and problem solved ...
I'm not suggesting that this build needs studs ...
[Re: JohnRR]
#1656292
08/08/14 11:40 AM
08/08/14 11:40 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Sheldon
or the dowel pins ?
Agreed...I've seen head gasket problems (blow outs) from having milled heads, and decked blocks an the assembler didn't dry fit (no gasket) the head to see if the dowels were too long....sometimes it's the simplest of things that cause major issues, always double check everything
mike
[Re: GregY]
#1656295
08/08/14 03:12 PM
08/08/14 03:12 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
I used some FelPro 1009's once that apparently overhung and blew.
When exactly did this happen? Was it with these heads and after the machining?
How did you discover that water was getting into a cylinder?
[Re: BSB67]
#1656296
08/08/14 08:20 PM
08/08/14 08:20 PM
GregY
Rochester, New York
No this was in the motors old days. All the stuff (heads/machine work) is new. Motor was broken in and dyno tested, the shop didn't report any problems. Started spewing coolant as soon as I got it installed (which was like a year after I got it back, I am a slow worker) and started it.
The water got in the oil too, not just the combustion chamber. Does that offer any clues as to what is happening?
Also, I am not going to buy new head bolts, I am going to check the bolt and dowel lenghts, and I am going to buy better gaskets, probably the recommended Edelbrock 7325.
Maybe I am already insane, and that is causing my car problems, not the other way around!
Thanks for all the help, it is really appreciated.
Greg
