stock or super stock rear springs?? #165474
12/10/08 03:30 PM
12/10/08 03:30 PM
London,Ontario,Canada
1962Savoy Offline OP
I would like to know the difference between the stock and super stock rear springs. I'm thinking of replacing my stock ones
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165475
12/10/08 04:19 PM
12/10/08 04:19 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
All I know is that I bought the MP SS springs to replace my factory XHD (Hemi) springs and I got a nice 4" lift on the back! I don't know if they sent me the wrong ones or what, but now I've ordered a set of XHD replacements and the SS springs will make nice wall ornaments.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: stock or super stock rear springs?? [Re: DPelletier] #165476
12/10/08 04:28 PM
12/10/08 04:28 PM
toronto canada
69chargeryeehaa Offline
toronto canada
i agree, my old charger had those ss springs, front torsion bars cranked all the way up to even it out, unless you like that look, it's alright, and with the right tires it looks ok....rears are 275/60/15's on 10" prostar draglites. but it was border line 4x4..
Re: stock or super stock rear springs?? [Re: 69chargeryeehaa] #165477
12/10/08 04:38 PM
12/10/08 04:38 PM
toronto canada
toronto canada
here's my current 69 r/t with the same rims...stock r/t springs.
Re: stock or super stock rear springs?? [Re: 69chargeryeehaa] #165478
12/10/08 04:40 PM
12/10/08 04:40 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I have the 2800lb S/S springs in my Barracuda. That thing rides like an empty garbage truck!
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: stock or super stock rear springs?? [Re: 69L78Nova] #165479
12/10/08 05:28 PM
12/10/08 05:28 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The SS springs were designed for drag racing, and teh leaves are oriented so that they're biased toward the front section of the spring to resist "wind-up" or deflection. The typical amount of ride height increase is around 1.5"-2" as they also have more arch. If you use the 002/003 springs, AKA "3,000-lb A-body", you'll find that the R/R will sit higher than the L/R. This can be avoided by using 2 of the same #, or adjusted out using the torsion bar height adjustment. A requirement with SS springs is to use a longer ("taller") rear shock, as the SS springs allow more chassis/axle separation. Imperial rear shocks, or old D100 ft shocks, are the cheapest way to go. The SS springs are pretty "lively", so on the street a shock with more control might be necessary to reduce the bouncing.
Re: stock or super stock rear springs?? [Re: 69chargeryeehaa] #165480
12/10/08 06:36 PM
12/10/08 06:36 PM
DPelletier Offline
DPelletier  Offline
If mine looked like yours I would be OK with it, but mine actually has an honest 4-5" between the fender lip and the top of the tire using the MP SS springs!
Even with the proper, longer spring perches my shackles lie flat against the frame.
Re: stock or super stock rear springs?? [Re: DPelletier] #165481
12/10/08 06:41 PM
12/10/08 06:41 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
The springs are supposed to go UNDER the axle !!
Re: stock or super stock rear springs?? [Re: DPelletier] #165482
12/10/08 06:41 PM
12/10/08 06:41 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
I just ordered a set of 002 & 003 springs this week. I hope they are ok, there seams to be many opinions on these. I have heard and read everything from love em gotta have em to Mopar junk quality issues. I plan on using a couple of lowering blocks if needed to adjust the ride height on the street. I hope I didn't just waste $250 bucks.
Re: stock or super stock rear springs?? [Re: DPelletier] #165483
12/10/08 06:43 PM
12/10/08 06:43 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
I used a three position front hanger on my springs to lower them here is a link to something similar and a picture.
http://chucker54.stores.yahoo.net/manciniracing20.html
Re: stock or super stock rear springs?? [Re: 68Fastback] #165484
12/10/08 06:45 PM
12/10/08 06:45 PM
mrpatel Offline
mrpatel  Offline
Thanks!
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165485
12/10/08 06:46 PM
12/10/08 06:46 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a customers car, 69 RoadRunner,under going a "restomod"......SS springs, running a Hoosier 31X15X15 "racing" tire......the car SITS up there!....stiff Too!
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165486
12/10/08 06:47 PM
12/10/08 06:47 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
first, thats a really neat '62! i really like the early b-bodies, especially '62's. i was looking thru a mopar chassis manual and it says the '62's have 20" front segment and a 35" rear segment, the same as a-bodies. perhaps mancini's xhd a-body springs would work (bolt up) and not raise the back up a bunch, . just an idea.
Re: stock or super stock rear springs?? [Re: 68Fastback] #165487
12/10/08 06:54 PM
12/10/08 06:54 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This Customer car has them also,.....they are currently on the upper hole, or the "lowest" you can go ......keep in mind that's a 31 " tall tire!
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165488
12/10/08 07:20 PM
12/10/08 07:20 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Looks like a street car. I would stick with a stock replacement or an XHD spring that ESPO sells.
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165489
12/10/08 07:25 PM
12/10/08 07:25 PM
Indiana
P
Pentastar440 Offline
P
Indiana
SS springs are for race cars. Why does anyone put them on street cars and then complain about the way they sit or how they ride ??
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: stock or super stock rear springs?? [Re: Pentastar440] #165490
12/10/08 07:41 PM
12/10/08 07:41 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Ya dont hear me complaining. This car hooks too good with the S/S springs. The stock springs were like a wet noodle when faced with a 4800rpm WOT clutch dump!
1969 Nova
454/M21/3.31
5.0/4R70W/3.55
(Daily driver)
Re: stock or super stock rear springs?? [Re: DAYCLONA] #165491
12/10/08 07:50 PM
12/10/08 07:50 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Wow that side view really says it all, hopefully they will settle down some, mine did but only about an inch, is there still space for a taller perch if you had one made by someone like AndyF.
Re: stock or super stock rear springs?? [Re: 1962Savoy] #165492
12/10/08 10:40 PM
12/10/08 10:40 PM
AndyF Online content
AndyF  Online Content
I run SS springs on my '65 Coronet. They work fine if you get the correct ones. For a street car you might consider getting two left side springs rather than a left and a right.
I have 3800 lb four speed springs on this car and the rear end sits down just fine.
Re: stock or super stock rear springs?? [Re: AndyF] #165493
12/10/08 11:08 PM
12/10/08 11:08 PM
Nebraska
BLUECUDA Offline
super street
BLUECUDA  Offline
super street
Nebraska
This is what my Cuda looks like with SS springs
