Re: stock or super stock rear springs??
[Re: 1962Savoy]
#165475
12/10/08 04:19 PM
12/10/08 04:19 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
All I know is that I bought the MP SS springs to replace my factory XHD (Hemi) springs and I got a nice 4" lift on the back! I don't know if they sent me the wrong ones or what, but now I've ordered a set of XHD replacements and the SS springs will make nice wall ornaments. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: 69chargeryeehaa]
#165478
12/10/08 04:40 PM
12/10/08 04:40 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I have the 2800lb S/S springs in my Barracuda. That thing rides like an empty garbage truck!
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#165479
12/10/08 05:28 PM
12/10/08 05:28 PM
Posts: 20,832 A collage of whims
topside
A collage of whims
The SS springs were designed for drag racing, and teh leaves are oriented so that they're biased toward the front section of the spring to resist "wind-up" or deflection. The typical amount of ride height increase is around 1.5"-2" as they also have more arch. If you use the 002/003 springs, AKA "3,000-lb A-body", you'll find that the R/R will sit higher than the L/R. This can be avoided by using 2 of the same #, or adjusted out using the torsion bar height adjustment. A requirement with SS springs is to use a longer ("taller") rear shock, as the SS springs allow more chassis/axle separation. Imperial rear shocks, or old D100 ft shocks, are the cheapest way to go. The SS springs are pretty "lively", so on the street a shock with more control might be necessary to reduce the bouncing.
#165480
12/10/08 06:36 PM
12/10/08 06:36 PM
DPelletier
i agree, my old charger had those ss springs, front torsion bars cranked all the way up to even it out, unless you like that look, it's alright, and with the right tires it looks ok....rears are 275/60/15's on 10" prostar draglites. but it was border line 4x4..
If mine looked like yours I would be OK with it, but mine actually has an honest 4-5" between the fender lip and the top of the tire using the MP SS springs!
Even with the proper, longer spring perches my shackles lie flat against the frame.
1974 'Cuda
[Re: DPelletier]
#165481
12/10/08 06:41 PM
12/10/08 06:41 PM
Posts: 8,884 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The springs are supposed to go UNDER the axle !!
[Re: 1962Savoy]
#165486
12/10/08 06:47 PM
12/10/08 06:47 PM
Posts: 3,916 usa
lewtot184
usa
I would like to know the difference between the stock and super stock rear springs. I'm thinking of replacing my stock ones
first, thats a really neat '62! i really like the early b-bodies, especially '62's. i was looking thru a mopar chassis manual and it says the '62's have 20" front segment and a 35" rear segment, the same as a-bodies. perhaps mancini's xhd a-body springs would work (bolt up) and not raise the back up a bunch, . just an idea.
[Re: 68Fastback]
#165487
12/10/08 06:54 PM
12/10/08 06:54 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I used a three position front hanger on my springs to lower them here is a link to something similar and a picture.
http://chucker54.stores.yahoo.net/manciniracing20.html
This Customer car has them also,.....they are currently on the upper hole, or the "lowest" you can go ......keep in mind that's a 31 " tall tire!
[Re: 1962Savoy]
#165488
12/10/08 07:20 PM
12/10/08 07:20 PM
Posts: 16,153 Mesa, Arizona
dart4forte
Mesa, Arizona
Looks like a street car. I would stick with a stock replacement or an XHD spring that ESPO sells.
[Re: Pentastar440]
#165490
12/10/08 07:41 PM
12/10/08 07:41 PM
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
Ya dont hear me complaining. This car hooks too good with the S/S springs. The stock springs were like a wet noodle when faced with a 4800rpm WOT clutch dump!
[Re: DAYCLONA]
#165491
12/10/08 07:50 PM
12/10/08 07:50 PM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
Wow that side view really says it all, hopefully they will settle down some, mine did but only about an inch, is there still space for a taller perch if you had one made by someone like AndyF.
