Small Block motor porn
#1654784
08/04/14 02:37 AM
08/04/14 02:37 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Here's a motor I just wrapped up for a buddy while I save up to rebuild mine. It's a 416 Scat rotating assymbly from Todd Marsh, CNC prepped Eldelbrock heads from Hughes Engine as well as one of their hydraulic cams.
Putting it on the dyno Thursday, hoping for 500 HP.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Small Block motor porn
[Re: MR_P_BODY]
#1654791
08/04/14 01:12 PM
08/04/14 01:12 PM
Quicktree
Cool... I like the valve covers... whos are they
looks like a powder coated procomp
[Re: Quicktree]
#1654792
08/05/14 12:19 PM
08/05/14 12:19 PM
Posts: 12,129 Cleveland
sunroofgtx
Cleveland
Looks great, Wade. Great luck with the pulls. Need anything?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
[Re: WadeMetzinger]
#1654794
08/05/14 12:54 PM
08/05/14 12:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I will suggest that you cut the tie bars between the header flanges to let them grow without worping the flanges
[Re: dtedler]
#1654797
08/05/14 01:53 PM
08/05/14 01:53 PM
MR_P_BODY
I thought that's why the good headers have the 3/8" thick flanges now is to resist the warping. I like your idea though.
Also a VERY important thing to do is drill 1 of the holes to a larger diameter to allow the flange to slide instead of worping(if you have 2 5/16 bolts holding each tube or the pair of tubes drill 1 hole to 3/8")
[Re: WadeMetzinger]
#1654800
08/05/14 02:21 PM
08/05/14 02:21 PM
MR_P_BODY
Yeah most guys dont want to cut them on coated headers.. I cut them off before I take them to get coated... if he wants to he should drill 1 hole larger per set of tubes and that would be covered by the bolt/nut head
[Re: MR_P_BODY]
#1654801
08/05/14 02:40 PM
08/05/14 02:40 PM
sunroofgtx
Cleveland
Looks great, Wade. Thanks. I almost bought those wires..haha.
