Small Block motor porn #1654784
08/04/14 02:37 AM
08/04/14 02:37 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
Here's a motor I just wrapped up for a buddy while I save up to rebuild mine. It's a 416 Scat rotating assymbly from Todd Marsh, CNC prepped Eldelbrock heads from Hughes Engine as well as one of their hydraulic cams.
Putting it on the dyno Thursday, hoping for 500 HP.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Small Block motor porn [Re: WadeMetzinger] #1654785
08/04/14 02:38 AM
08/04/14 02:38 AM
Tulsa, Ok
Tulsa, Ok
Pic 2
Re: Small Block motor porn [Re: WadeMetzinger] #1654786
08/04/14 02:39 AM
08/04/14 02:39 AM
Tulsa, Ok
Tulsa, Ok
Pic 3
Re: Small Block motor porn [Re: WadeMetzinger] #1654787
08/04/14 02:55 AM
08/04/14 02:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Purdy!
Re: Small Block motor porn [Re: WadeMetzinger] #1654788
08/04/14 03:07 AM
08/04/14 03:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool... I like the valve covers... whos are they
Re: Small Block motor porn [Re: MR_P_BODY] #1654789
08/04/14 09:27 AM
08/04/14 09:27 AM
Tulsa, Ok
Tulsa, Ok
Mopar, P5155525, I guess they are new, I've never seen them before. Not cheap though, $300.
Re: Small Block motor porn [Re: WadeMetzinger] #1654790
08/04/14 12:07 PM
08/04/14 12:07 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
nice. hope you hit your target.
Re: Small Block motor porn [Re: MR_P_BODY] #1654791
08/04/14 01:12 PM
08/04/14 01:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
looks like a powder coated procomp
Re: Small Block motor porn [Re: Quicktree] #1654792
08/05/14 12:19 PM
08/05/14 12:19 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Looks great, Wade. Great luck with the pulls. Need anything?
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Small Block motor porn [Re: sunroofgtx] #1654793
08/05/14 12:44 PM
08/05/14 12:44 PM
Tulsa, Ok
Tulsa, Ok
I've got FireCore wire on it, new but I got them from someone in the race parts section. I need to get an updated pictures.
Re: Small Block motor porn [Re: WadeMetzinger] #1654794
08/05/14 12:54 PM
08/05/14 12:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I will suggest that you cut the tie bars between the
header flanges to let them grow without worping the
flanges
Re: Small Block motor porn [Re: MR_P_BODY] #1654795
08/05/14 12:58 PM
08/05/14 12:58 PM
Columbia, Missouri
dtedler Offline
dtedler  Offline
Columbia, Missouri
I thought that's why the good headers have the 3/8" thick flanges now is to resist the warping. I like your idea though.
Re: Small Block motor porn [Re: dtedler] #1654796
08/05/14 01:33 PM
08/05/14 01:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With that bar in there it tries to push both ways
as it heats up and tends to flex the flanges... yes
the 3/8 flange is better for sealing and less resistant
to worping but given enough heat and force even they
will worp... thats why you try yo help it all you can..
its easier to make a flange with the tie bars in there
and to cut them off would be added expense
EDIT
Even a saw cut width is good enough but on the headers
I build I contour the flange and get rid of all the
tie bar
Re: Small Block motor porn [Re: dtedler] #1654797
08/05/14 01:53 PM
08/05/14 01:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also a VERY important thing to do is drill 1 of the
holes to a larger diameter to allow the flange to slide
instead of worping(if you have 2 5/16 bolts holding
each tube or the pair of tubes drill 1 hole to 3/8")
Re: Small Block motor porn [Re: MR_P_BODY] #1654798
08/05/14 02:10 PM
08/05/14 02:10 PM
Tulsa, Ok
Tulsa, Ok
I didn't do that with my other set of TTI's and I haven't had any issues but I see your point and if these weren't my buddies and polished ceramic coated I'd ask him about doing that but he is planning to take it to car shows so this wouldn't look as nice. But thanks for the suggestion!
Here is a picture on the engine cradle with wires and ready for the dyno.
Re: Small Block motor porn [Re: WadeMetzinger] #1654799
08/05/14 02:15 PM
08/05/14 02:15 PM
Tulsa, Ok
Tulsa, Ok
Other side
Re: Small Block motor porn [Re: WadeMetzinger] #1654800
08/05/14 02:21 PM
08/05/14 02:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah most guys dont want to cut them on coated headers..
I cut them off before I take them to get coated...
if he wants to he should drill 1 hole larger per set
of tubes and that would be covered by the bolt/nut head
Re: Small Block motor porn [Re: MR_P_BODY] #1654801
08/05/14 02:40 PM
08/05/14 02:40 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Looks great, Wade. Thanks. I almost bought those wires..haha.
