Cut to length push rods #1652247
07/29/14 12:51 AM
07/29/14 12:51 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Years ago (many) I purchaced a push rod kit from Mopar Performance that you cut to lenght then finnished putting them together. They had a long push rod finnished on the bottom, a cup, a drill to open up the ID where the cup fit(after you cut to lenght) and a fixture to hold the push rod while you pressed the cup in. Thick walled CM I belive.
Does anyone offer a kit like that anymore?
Brian
Re: Cut to length push rods [Re: '72CudaRacer] #1652248
07/29/14 12:57 AM
07/29/14 12:57 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Last I knew mancini had them. That has been a few years also. HTH Beep
Re: Cut to length push rods [Re: '72CudaRacer] #1652249
07/29/14 01:03 AM
07/29/14 01:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian
I have a hand full of them if you want them.. the
ball end is 3/8 and doesnt fit anything I own... its
not a full set because I stripped it for a few pieces
of tubing... the newer sets the tip(cup) were a bit
loose but MP said that wasnt a problem and really it isnt
Re: Cut to length push rods [Re: MR_P_BODY] #1652250
07/29/14 04:05 AM
07/29/14 04:05 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use Comp Cams cut to length pushrods & bought the special drill they sell to cut them down plus ream the inside for the cup to fit. they press in very easily plus you can buy the correct 5/16 ball n cup combo.
Re: Cut to length push rods [Re: '72CudaRacer] #1652251
07/29/14 04:31 AM
07/29/14 04:31 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
I've used the Mancini ones on multiple engines with no problems.
Re: Cut to length push rods [Re: Mcode69] #1652252
07/29/14 09:20 AM
07/29/14 09:20 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
The Mancini ones used to be made by trend (diamond) now the get them from some one else.
JAKES AUTOMOTIVE
Re: Cut to length push rods [Re: '72CudaRacer] #1652253
07/29/14 07:30 PM
07/29/14 07:30 PM
oh
julian2007 Offline
julian2007  Offline
oh
trend is great and very reasonable to buy, its not worth making sub standard ones your self.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Cut to length push rods [Re: julian2007] #1652254
07/29/14 08:04 PM
07/29/14 08:04 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
you can buy kits to put together from trend also. I do all the time.
JAKES AUTOMOTIVE
Re: Cut to length push rods [Re: JAKE68] #1652255
07/29/14 10:02 PM
07/29/14 10:02 PM
NC
440Jim Offline
440Jim  Offline
NC
Do any of them have thick walled pushrods (over 0.080")?
Re: Cut to length push rods [Re: 440Jim] #1652256
07/29/14 11:07 PM
07/29/14 11:07 PM
Mooresburg, Tn
Mooresburg, Tn
This engine needs a push rod approx 9.725" long.
Brian
Re: Cut to length push rods [Re: '72CudaRacer] #1652257
07/30/14 12:49 AM
07/30/14 12:49 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Brian, Indy has cut to fit, but you can get a custom set made from Trend most of the time get them the next day with express shipping.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Cut to length push rods [Re: JAKE68] #1652258
07/30/14 03:02 PM
07/30/14 03:02 PM
oh
julian2007 Offline
julian2007  Offline
oh
I believe you but why waste you time, you can get them next day if needed and for what they charge for custom push rods I can't see much savings in doing it your self.
Re: Cut to length push rods [Re: julian2007] #1652259
07/30/14 08:59 PM
07/30/14 08:59 PM
USA
N
Nitrofish Offline
Nitrofish  Offline
N
USA
I personally have had bad luck with cut to length pushrods and I wouldnt go down that road again.
I highly recommend Smith Brothers pushrods
http://www.pushrods.net/
Re: Cut to length push rods [Re: '72CudaRacer] #1652260
08/03/14 05:03 AM
08/03/14 05:03 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just bought these at the Mopar Car/Show race at Bandimere in June in the swap meet area.
Old Mopar number 4007284. I googled the number and found this number p5249815, and this place selling them for $118.80.
http://www.autopartsmopar.com/oe-mopar/p5249815
I'll sell you mine for $75
Re: Cut to length push rods [Re: Nitrofish] #1652261
08/03/14 11:32 AM
08/03/14 11:32 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
