Re: Name brand tubes for slicks
[Re: cruzin]
#1651036
07/25/14 08:05 PM
07/25/14 08:05 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I say a quality tube is money well spent....My Firestone Tubes are over 20 years old and they still hold air,and are in excellent condition.
[Re: Chris2581]
#1651037
07/25/14 08:22 PM
07/25/14 08:22 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
I would buy the Mickey part number recommended for your tire....... Your still going well over 100mph in an 11-12 sec car
[Re: cruzin]
#1651038
07/25/14 08:22 PM
07/25/14 08:22 PM
Posts: 200 AB
Efidart
AB
You can run a standard tube with a grommet and some baby powder just fine at that level. If it 60's real hard be sure to screw the tires.
Goto your local tire shop and see what they have for standard tubes.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#1651039
07/25/14 11:07 PM
07/25/14 11:07 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
No bud......GET THE M/T tubes......75 bucks apiece but been that regular tube route before. Nothing worse than a tube coming apart on the way back to the pits!! Regular tubes just don't have the strength.
[Re: cudatom]
#1651041
07/28/14 05:29 PM
07/28/14 05:29 PM
Posts: 200 AB
Efidart
AB
Baby powder is the key on any tube including M/Ts. I have installed lots with MR 14/15 tubes at our tire shop, do not run a KR as they are too small for a slick that size. If your wheels are drilled for the Air/Water type stem be sure to put a grommet in.
Mickey Thompson tubes are better that's for sure, but you don't need it at that level.
