Name brand tubes for slicks #1651035
07/25/14 07:24 PM
07/25/14 07:24 PM
Tucson, AZ
cruzin Offline OP
cruzin  Offline OP
Tucson, AZ
I got new slicks (Mickey Thompson 3055S) which are 9.0" x 28" stiffer sidewall tire. Car is a street strip 11-12 sec. I'm going to use a tube (it's recommended) with these tires.
What is the general consensus? Is it necessary to go with a MT, Hoosier or other name brand /race tube? I realize that the natural rubber tubes likely cost more for that reason. On the other hand since I’m not running Pro Stock, would a non-name brand tube be perfectly acceptable given my application?
Re: Name brand tubes for slicks [Re: cruzin] #1651036
07/25/14 08:05 PM
07/25/14 08:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I say a quality tube is money well spent....My Firestone Tubes are over 20 years old and they still hold air,and are in excellent condition.
Nautilus Racing-
Re: Name brand tubes for slicks [Re: Chris2581] #1651037
07/25/14 08:22 PM
07/25/14 08:22 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I would buy the Mickey part number recommended for your tire.......
Your still going well over 100mph in an 11-12 sec car
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Name brand tubes for slicks [Re: cruzin] #1651038
07/25/14 08:22 PM
07/25/14 08:22 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
You can run a standard tube with a grommet and some baby powder just fine at that level. If it 60's real hard be sure to screw the tires.
Goto your local tire shop and see what they have for standard tubes.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Name brand tubes for slicks [Re: Efidart] #1651039
07/25/14 11:07 PM
07/25/14 11:07 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
No bud......GET THE M/T tubes......75 bucks apiece but been that regular tube route before. Nothing worse than a tube coming apart on the way back to the pits!! Regular tubes just don't have the strength.
Re: Name brand tubes for slicks [Re: superwrench] #1651040
07/26/14 01:15 AM
07/26/14 01:15 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Agreed tried that back in the 80's and got 2 runs out of them. The tire didnt move(was screwed to the rim). Once you hold a regular tube in one hand and one designed for slicks in the other you will see why. No comparison. I too have a set that is at least 25 yrs old and still going strong.
Ok
Re: Name brand tubes for slicks [Re: cudatom] #1651041
07/28/14 05:29 PM
07/28/14 05:29 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
Baby powder is the key on any tube including M/Ts. I have installed lots with MR 14/15 tubes at our tire shop, do not run a KR as they are too small for a slick that size. If your wheels are drilled for the Air/Water type stem be sure to put a grommet in.
Mickey Thompson tubes are better that's for sure, but you don't need it at that level.
Re: Name brand tubes for slicks [Re: Efidart] #1651042
07/28/14 05:41 PM
07/28/14 05:41 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have had good luck using agriculture implement tubes. They are heavy duty and friendlier on the back pocket.
Re: Name brand tubes for slicks [Re: rt66jim] #1651043
07/29/14 11:08 AM
07/29/14 11:08 AM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
I just bought those tires and put the M/T tubes in with them.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
