Re: should i add the windage tray to my 340 stroker
[Re: hp340nos]
#1650264
07/24/14 12:19 AM
07/24/14 12:19 AM
Posts: 7,506 Az
Crizila
Az
I went with the tray on my stroker. Matter of preference. If you are going with a relatively stock oiling system and 7 / 8 qt or oil pan, I'd go with the tray. JMO.
Fastest 300
[Re: Crizila]
#1650265
07/24/14 02:06 AM
07/24/14 02:06 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I believe that Ryan, Shadydell, has done dyno testing and said it doesn't really have any benifits and doesn't recommend using a wind age tray on small blocks.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: Crizila]
#1650267
07/24/14 12:38 PM
07/24/14 12:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Doesn't address "slosh" and I wasn't overly enthusiastic about the baffling in my Milodon 8 qt pan.
In the pan I built for the 416 I put 1 wall in it with a one way door to keep the oil near the pick up and I put a lip on the back wall to keep slosh off the rear main... being that the pan will hold 10qts I run it low on the stick(its 8 qts when its set to run) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Crizila]
#1650269
07/24/14 02:30 PM
07/24/14 02:30 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
I didn't know windage trays were used to control slosh ?
[Re: JohnRR]
#1650270
07/24/14 03:32 PM
07/24/14 03:32 PM
dartman366
Mt. Vernon, Ohio
I didn't either, as far as a windage tray, don't waste your time If I were to do anything then put a scraper in it and don't look back. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dartman366]
#1650271
07/24/14 03:57 PM
07/24/14 03:57 PM
Posts: 8,165 Left Coast
BobR
Left Coast
I took mine off of my stocker and it went faster.
[Re: 408Dust]
#1650273
07/24/14 05:07 PM
07/24/14 05:07 PM
Quicktree
I have one on the shelf you can have,don't bother picked up 9 hp on the dyno with it removed.
yep waste of time
