should i add the windage tray to my 340 stroker #1650262
07/23/14 11:52 PM
07/23/14 11:52 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i have my 340 stroker 418 cid tore down due to roller lifter problems,should i add the windage tray when i put it back together?i havent been using the windage tray,what benefits would i get from the tray?street/strip motor shifted at 6000 rpm.thanks mike
Re: should i add the windage tray to my 340 stroker [Re: hp340nos] #1650263
07/24/14 12:00 AM
07/24/14 12:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A scraper is better
Re: should i add the windage tray to my 340 stroker [Re: hp340nos] #1650264
07/24/14 12:19 AM
07/24/14 12:19 AM
Az
Crizila Offline
Crizila  Offline
Az
I went with the tray on my stroker. Matter of preference. If you are going with a relatively stock oiling system and 7 / 8 qt or oil pan, I'd go with the tray. JMO.
Fastest 300
Re: should i add the windage tray to my 340 stroker [Re: Crizila] #1650265
07/24/14 02:06 AM
07/24/14 02:06 AM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I believe that Ryan, Shadydell, has done dyno testing and said it doesn't really have any benifits and doesn't recommend using a wind age tray on small blocks.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: should i add the windage tray to my 340 stroker [Re: WadeMetzinger] #1650266
07/24/14 11:57 AM
07/24/14 11:57 AM
Az
Crizila Offline
Crizila  Offline
Az
Doesn't address "slosh" and I wasn't overly enthusiastic about the baffling in my Milodon 8 qt pan.
Fastest 300
Re: should i add the windage tray to my 340 stroker [Re: Crizila] #1650267
07/24/14 12:38 PM
07/24/14 12:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the pan I built for the 416 I put 1 wall in it with
a one way door to keep the oil near the pick up and
I put a lip on the back wall to keep slosh off the
rear main... being that the pan will hold 10qts I
run it low on the stick(its 8 qts when its set to run)
Re: should i add the windage tray to my 340 stroker [Re: MR_P_BODY] #1650268
07/24/14 01:16 PM
07/24/14 01:16 PM
Az
Crizila Offline
Crizila  Offline
Az
Way to do it. If I did something like that I would probably go with w scraper also. I run 7 qts in my 8 qt pan.
Fastest 300
Re: should i add the windage tray to my 340 stroker [Re: Crizila] #1650269
07/24/14 02:30 PM
07/24/14 02:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know windage trays were used to control slosh ?
Re: should i add the windage tray to my 340 stroker [Re: JohnRR] #1650270
07/24/14 03:32 PM
07/24/14 03:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I didn't either, as far as a windage tray, don't waste your time If I were to do anything then put a scraper in it and don't look back.
Re: should i add the windage tray to my 340 stroker [Re: dartman366] #1650271
07/24/14 03:57 PM
07/24/14 03:57 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I took mine off of my stocker and it went faster.
Re: should i add the windage tray to my 340 stroker [Re: BobR] #1650272
07/24/14 04:05 PM
07/24/14 04:05 PM
408Dust Offline
408Dust  Offline
I have one on the shelf you can have,don't bother picked up 9 hp on the dyno with it removed.
Re: should i add the windage tray to my 340 stroker [Re: 408Dust] #1650273
07/24/14 05:07 PM
07/24/14 05:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
yep waste of time
Re: should i add the windage tray to my 340 stroker [Re: MR_P_BODY] #1650274
07/25/14 01:23 AM
07/25/14 01:23 AM
A scraper is better
I've heard as much as 30 HP at or above 6000 RPM on both NHRA 340 and 360 stockers I make my own, fit it tight, .045 to .060 at room temperatures It helps free up HP and it keeps oil in the oil pan Make some slosh(acceleration) and anti slosh(deacceleration) baffles in your oil pan if you don't have them already
Re: should i add the windage tray to my 340 stroker [Re: Cab_Burge] #1650275
07/25/14 11:34 AM
07/25/14 11:34 AM
Az
Crizila Offline
Crizila  Offline
Az
A scraper is better
30HP!! Guess I will be taking mine out - when my 4 bolt main cap on a stock 360 block conversion fails.
Fastest 300
