Trans question #1649819
07/22/14 06:58 PM
07/22/14 06:58 PM
Kingston, OK
racerb440 Offline OP
Kingston, OK
Can something in the trans cause 14% slippage? Turning 6000 rpm in the eighth at 98 mph. Thought convertor was bad, so I put in a new one. Still the same. According to Wallace calculator, I should only be turning about 5200
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
Re: Trans question [Re: racerb440] #1649820
07/22/14 07:29 PM
07/22/14 07:29 PM
dogdays Offline
dogdays  Offline
Accuracy of the tachometer?
R.
Re: Trans question [Re: dogdays] #1649821
07/22/14 07:35 PM
07/22/14 07:35 PM
Kingston, OK
Kingston, OK
Brand new AutoMeter playback tach
Re: Trans question [Re: racerb440] #1649822
07/23/14 12:19 AM
07/23/14 12:19 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
If it's the trans it will tell you sooner than later.
Re: Trans question [Re: racerb440] #1649823
07/23/14 02:05 AM
07/23/14 02:05 AM
Cab_Burge Online work
Cab_Burge  Online Work
Measure the circumference of YOUR rear tires and then do the math on how many feet per minute your running at the finish line If your running bias ply tires you might want to add 1 to 2.5 % to the circumference for tire growth If radial tires don't add anything more to the actual circumference Let us know what you find, tach errors and crummng converters can drive you absolutely NUTS Good luck
Re: Trans question [Re: racerb440] #1649824
07/23/14 02:19 AM
07/23/14 02:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a RMVB or a standard VB.. if standard
you could have real low line pressure
Re: Trans question [Re: MR_P_BODY] #1649825
07/23/14 07:53 AM
07/23/14 07:53 AM
Kingston, OK
Kingston, OK
It's a RMVB. What causes low line pressure? I don't know much about auto transmissions. Could bad clutches do this? Trans is only two years old.
Re: Trans question [Re: racerb440] #1649826
07/23/14 09:36 AM
07/23/14 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Being a RMVB your pressure is preset in the VB.. I
forget if you would have a throttle pressure on that..
I know the trans brake you dont get throttle pressure
and its locked... but I have the trans out of my Rampage
and between a bad shifter cable adjustment and low
throttle pressure it FRIED the low clutch(all the fiber
was gone)and it slipped
Re: Trans question [Re: racerb440] #1649827
07/23/14 05:05 PM
07/23/14 05:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes. Only way to know for sure is to disassemble. How is your 2-3 shift? Firm, slips into gear a little?
Re: Trans question [Re: John_Kunkel] #1649828
07/23/14 05:20 PM
07/23/14 05:20 PM
Kingston, OK
Kingston, OK
Seems to shift firm, however on both 1-2 and 2-3 rpm only drops about 500 rpm or so and that doesn't seem right
Re: Trans question [Re: racerb440] #1649829
07/24/14 10:35 PM
07/24/14 10:35 PM
Kingston, OK
Kingston, OK
Just checked line pressure. Read 115 psi 3rd gear 2000rpm. Is this too low for a RMVB? Could this cause the clutches to slip?
Re: Trans question [Re: racerb440] #1649830
07/24/14 11:09 PM
07/24/14 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe one of the trans guys will answer this .. but
I run 180 to 190
Re: Trans question [Re: MR_P_BODY] #1649831
07/24/14 11:27 PM
07/24/14 11:27 PM
Kingston, OK
Kingston, OK
Thank you. I'd ask my trans man, but I think I made him mad when I said there might be a problem with his trans. Can't seem to be able to get ahold of him now.
Re: Trans question [Re: racerb440] #1649832
07/25/14 02:50 PM
07/25/14 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You have to know what VB you have and what its line pressure is supposed to be. Where are you measuring the line pressure?
Re: Trans question [Re: John_Kunkel] #1649833
07/25/14 03:29 PM
07/25/14 03:29 PM
Kingston, OK
Kingston, OK
Measuring it at line pressure outlet on right side. Trans man says it should be about 160 psi. Not sure of brand, but it is a reverse pattern manual w/ low band apply. Just wondering if low pressure could cause 14% slippage. Car launches good, but slips all the way down the track.
Re: Trans question [Re: racerb440] #1649834
07/26/14 12:06 AM
07/26/14 12:06 AM
The first custom built 8 inch race converter I bought and used in a "race car" was a Art Carr, it broke during the second run Bottom line was it was to loose, it would slow the car down .034 to .041 in ET and 3 to 4 MPH in the 1/4 mile over the stock 11 inch street hemi converter It would revved like crazy at the hit of the throttle, go to 6000 RPM and stay there for a while in 1st gear and then accelerate up to 7000 RPM on the shift points, it would drop back to 6000 RPM and lay there again for awhile before strting to gain RPM, it was a real turd My message is your converter may be no good like that one I've since had two more bad 8 inch converters like that, one TCI and one GER I've also had several very good converters from A-1, B&M, Rossi, Continental, Turbo Action and several other good comapnys. Buy the best race converter you can find Not the cheaper ones
Re: Trans question [Re: racerb440] #1649835
07/26/14 07:33 PM
07/26/14 07:33 PM
Dallas, TX
440Brian Offline
440Brian  Offline
Dallas, TX
My converter slippage decreases during the run. It's much lower after a 1/4 mile than an 1/8th. Mine is about twice that at that point on a run, but I'm measuring it using engine rpm/driveshaft rpm.
Re: Trans question [Re: 440Brian] #1649836
07/26/14 07:43 PM
07/26/14 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A 1/4 mile run has a lot more of pulling rpm than a
1/8 mile run and will show a lesser/better slippage rate
Re: Trans question [Re: MR_P_BODY] #1649837
07/27/14 03:03 AM
07/27/14 03:03 AM
Kingston, OK
Kingston, OK
Well, Kenny at PTC convinced me that both my converters which were built to run at 6000' above sea level are going to be way too loose down here at almost sea level, so I've got a new 8 inch race unit on the way. Thanks for all the help, everybody.
