Re: Trans question
[Re: dogdays]
#1649821
07/22/14 07:35 PM
07/22/14 07:35 PM
Posts: 62 Kingston, OK
racerb440
Kingston, OK
Brand new AutoMeter playback tach
Bob - 67 Dodge Coronet 11.35,116.95 at 5880'
Re: Trans question
[Re: MR_P_BODY]
#1649825
07/23/14 07:53 AM
07/23/14 07:53 AM
racerb440
Kingston, OK
It's a RMVB. What causes low line pressure? I don't know much about auto transmissions. Could bad clutches do this? Trans is only two years old.
Re: Trans question
[Re: racerb440]
#1649826
07/23/14 09:36 AM
07/23/14 09:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Being a RMVB your pressure is preset in the VB.. I forget if you would have a throttle pressure on that.. I know the trans brake you dont get throttle pressure and its locked... but I have the trans out of my Rampage and between a bad shifter cable adjustment and low throttle pressure it FRIED the low clutch(all the fiber was gone)and it slipped
Re: Trans question
[Re: John_Kunkel]
#1649828
07/23/14 05:20 PM
07/23/14 05:20 PM
racerb440
Kingston, OK
Seems to shift firm, however on both 1-2 and 2-3 rpm only drops about 500 rpm or so and that doesn't seem right
Re: Trans question
[Re: racerb440]
#1649829
07/24/14 10:35 PM
07/24/14 10:35 PM
racerb440
Kingston, OK
Just checked line pressure. Read 115 psi 3rd gear 2000rpm. Is this too low for a RMVB? Could this cause the clutches to slip?
Re: Trans question
[Re: racerb440]
#1649830
07/24/14 11:09 PM
07/24/14 11:09 PM
MR_P_BODY
Maybe one of the trans guys will answer this .. but I run 180 to 190
Re: Trans question
[Re: MR_P_BODY]
#1649831
07/24/14 11:27 PM
07/24/14 11:27 PM
racerb440
Kingston, OK
Thank you. I'd ask my trans man, but I think I made him mad when I said there might be a problem with his trans. Can't seem to be able to get ahold of him now.
Re: Trans question
[Re: racerb440]
#1649832
07/25/14 02:50 PM
07/25/14 02:50 PM
Posts: 25,843 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You have to know what VB you have and what its line pressure is supposed to be. Where are you measuring the line pressure?
Re: Trans question
[Re: John_Kunkel]
#1649833
07/25/14 03:29 PM
07/25/14 03:29 PM
racerb440
Kingston, OK
Measuring it at line pressure outlet on right side. Trans man says it should be about 160 psi. Not sure of brand, but it is a reverse pattern manual w/ low band apply. Just wondering if low pressure could cause 14% slippage. Car launches good, but slips all the way down the track.
Re: Trans question
[Re: racerb440]
#1649834
07/26/14 12:06 AM
07/26/14 12:06 AM
Posts: 43,213 Bend,OR USA
Cab_Burge
The first custom built 8 inch race converter I bought and used in a "race car" was a Art Carr, it broke during the second run Bottom line was it was to loose, it would slow the car down .034 to .041 in ET and 3 to 4 MPH in the 1/4 mile over the stock 11 inch street hemi converter It would revved like crazy at the hit of the throttle, go to 6000 RPM and stay there for a while in 1st gear and then accelerate up to 7000 RPM on the shift points, it would drop back to 6000 RPM and lay there again for awhile before strting to gain RPM, it was a real turd My message is your converter may be no good like that one I've since had two more bad 8 inch converters like that, one TCI and one GER I've also had several very good converters from A-1, B&M, Rossi, Continental, Turbo Action and several other good comapnys. Buy the best race converter you can find Not the cheaper ones
Re: Trans question
[Re: 440Brian]
#1649836
07/26/14 07:43 PM
07/26/14 07:43 PM
MR_P_BODY
My converter slippage decreases during the run. It's much lower after a 1/4 mile than an 1/8th. Mine is about twice that at that point on a run, but I'm measuring it using engine rpm/driveshaft rpm.
A 1/4 mile run has a lot more of pulling rpm than a 1/8 mile run and will show a lesser/better slippage rate
Re: Trans question
[Re: MR_P_BODY]
#1649837
07/27/14 03:03 AM
07/27/14 03:03 AM
racerb440
Kingston, OK
Well, Kenny at PTC convinced me that both my converters which were built to run at 6000' above sea level are going to be way too loose down here at almost sea level, so I've got a new 8 inch race unit on the way. Thanks for all the help, everybody.
