what's wrong with this ? #1649387
07/21/14 10:40 PM
07/21/14 10:40 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
60 ft is 1.36 1/8 et is 6.56...........
Indy headed 408 904 with low gearset
606hp @6400 553lbs @ 5200rpm
950 cfm proform main body
29x11 slicks
ladder bar suspension
5000 stall with this 60ft I should go faster and better et, no ?
Dan
Re: what's wrong with this ? [Re: Wedgeman] #1649388
07/21/14 10:46 PM
07/21/14 10:46 PM
Cab_Burge Online work
Cab_Burge  Online Work
29x11 slicks
Dan
Post the rest of the time slip numbers like the 330 and 1/8 MPH
Re: what's wrong with this ? [Re: Wedgeman] #1649389
07/21/14 10:53 PM
07/21/14 10:53 PM
Indy
496 A-body Offline
496 A-body  Offline
Indy
29x11 slicks
Dan
Car weight? Rear gear ratio? What RPM do you shift and what RPM when you hit the stripe? Have you flashed the converter?
Re: what's wrong with this ? [Re: 496 A-body] #1649390
07/21/14 11:42 PM
07/21/14 11:42 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
car weights 3100 with me
sorry no 330' or et on the time slip..............
Re: what's wrong with this ? [Re: Wedgeman] #1649391
07/22/14 12:55 AM
07/22/14 12:55 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Your 60 foot tells me it should be a lot faster.
Wallace Racing - 1/8th Mile ET/MPH/HP Calculator
Weight is as the car sits on the line; driver and gas in it.
Calculate ET and MPH from HP and Weight
Weight HP
Your ET / MPH computed from your vehicle weight of 3100 pounds and HP of 606 is
6.46 seconds and 107.95 MPH.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: what's wrong with this ? [Re: pittsburghracer] #1649392
07/22/14 12:57 AM
07/22/14 12:57 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed to a point though..............if everything else is up to snuff, could be just a great working suspension.
Re: what's wrong with this ? [Re: Thumperdart] #1649393
07/22/14 01:05 AM
07/22/14 01:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
What was the 1/8 mph ? I guess I would think it could be faster with that good of a 60. My 3700 lb 63 runs 6.80's in the 1/8 with a 1.50 sixty. Ron
Re: what's wrong with this ? [Re: 383man] #1649394
07/22/14 02:17 AM
07/22/14 02:17 AM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
Did you lose to the Mudstain?
Re: what's wrong with this ? [Re: Wedgeman] #1649395
07/22/14 02:41 AM
07/22/14 02:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What RPM are you hitting at the stripe and what RPM
are you shifting at and what gear are you in at the stripe
Re: what's wrong with this ? [Re: MR_P_BODY] #1649396
07/22/14 02:48 AM
07/22/14 02:48 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
What was your mph at the 1/8th? I didnt see it mentioned
Re: what's wrong with this ? [Re: demon440] #1649397
07/22/14 04:24 AM
07/22/14 04:24 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thought also crossed my mind.......
Re: what's wrong with this ? [Re: Wedgeman] #1649398
07/22/14 09:02 AM
07/22/14 09:02 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That's a good 60 foot. Is it laying down at all? Too much stall? I'd think w/ a 1.38 you'd be deeper in the 6's for sure.
Coming soon!!!!
Re: what's wrong with this ? [Re: Mr.Yuck] #1649399
07/22/14 09:48 AM
07/22/14 09:48 AM
gregsdart Offline
gregsdart  Offline
Converter stall you listed is below peak torque. That would hurt your times, but they don't look that far off. I would think at least 5500 stall would work better. I only have a 600 rpm window between stall and shift point, works great.
Re: what's wrong with this ? [Re: gregsdart] #1649400
07/22/14 10:03 AM
07/22/14 10:03 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
Short times are good! You need to be looking at why you are losing your good momentum down track. I'm guessing you are running around 101-103. May need to look into fuel jetting to get your top end mixture better, or even converter lock up.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: what's wrong with this ? [Re: slantzilla] #1649401
07/22/14 08:01 PM
07/22/14 08:01 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
C'mon.....
I was not that bad !!
Re: what's wrong with this ? [Re: Wedgeman] #1649402
07/22/14 08:06 PM
07/22/14 08:06 PM
johnmilner Offline
johnmilner  Offline
try an aed 750 hp ho.
Re: what's wrong with this ? [Re: johnmilner] #1649403
07/22/14 08:10 PM
07/22/14 08:10 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
It crossed my mind to try a smaller carb....
What about the AED ???
You have one ?
Dan
Re: what's wrong with this ? [Re: 496 A-body] #1649404
07/23/14 08:40 AM
07/23/14 08:40 AM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
29x11 slicks
Dan
I have a 4.56 Dana60, should I go with 30 or 31 in slicks ?
Re: what's wrong with this ? [Re: Wedgeman] #1649405
07/23/14 08:58 AM
07/23/14 08:58 AM
ill
dennismopar73 Offline
ill
You have one ?
Dan
All kinds of guess work here
Trans could be bad , vert could be a issue
Or both
Fuel delievery ie pump n line restrictions bad regulator.
Jetting a carb is done by heat , or the lack of heat
Timing plays a huge part as well .
With limited info, hard to say whats going on here
