Re: what's wrong with this ?
[Re: Wedgeman]
#1649389
07/21/14 10:53 PM
07/21/14 10:53 PM
Posts: 369 Indy
496 A-body
Indy
60 ft is 1.36 1/8 et is 6.56...........
Indy headed 408 904 with low gearset 606hp @6400 553lbs @ 5200rpm 950 cfm proform main body 29x11 slicks ladder bar suspension 5000 stall with this 60ft I should go faster and better et, no ?
Dan
Car weight? Rear gear ratio? What RPM do you shift and what RPM when you hit the stripe? Have you flashed the converter?
[Re: Wedgeman]
#1649391
07/22/14 12:55 AM
07/22/14 12:55 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Your 60 foot tells me it should be a lot faster.
Wallace Racing - 1/8th Mile ET/MPH/HP Calculator Weight is as the car sits on the line; driver and gas in it. Calculate ET and MPH from HP and Weight Weight HP Your ET / MPH computed from your vehicle weight of 3100 pounds and HP of 606 is 6.46 seconds and 107.95 MPH.
[Re: pittsburghracer]
#1649392
07/22/14 12:57 AM
07/22/14 12:57 AM
Thumperdart
State of confusion
Agreed to a point though..............if everything else is up to snuff, could be just a great working suspension.
[Re: Mr.Yuck]
#1649399
07/22/14 09:48 AM
07/22/14 09:48 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Converter stall you listed is below peak torque. That would hurt your times, but they don't look that far off. I would think at least 5500 stall would work better. I only have a 600 rpm window between stall and shift point, works great.
[Re: 496 A-body]
#1649404
07/23/14 08:40 AM
07/23/14 08:40 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
Dan
I have a 4.56 Dana60, should I go with 30 or 31 in slicks ?
[Re: Wedgeman]
#1649405
07/23/14 08:58 AM
07/23/14 08:58 AM
Posts: 2,177 ill
dennismopar73
ill
It crossed my mind to try a smaller carb....
What about the AED ??? You have one ?
Dan
All kinds of guess work here Trans could be bad , vert could be a issue Or both Fuel delievery ie pump n line restrictions bad regulator. Jetting a carb is done by heat , or the lack of heat Timing plays a huge part as well . With limited info, hard to say whats going on here
