64 Belvedere rear wheel advice #1649304
07/21/14 01:33 PM
07/21/14 01:33 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
I have a 64 Belvedere. Everything is stock in the suspension. I want to put 275/60 radials on and not have any problems. I have 15x8 rear wheels with 4.5 backspacing. The tires are rubbing the inner quarter panels. Any suggestions ? I thought that this size wheel was supposed to clear with a 275/60 tire.
J.C. Childress (434) 665-9541
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649305
07/21/14 02:02 PM
07/21/14 02:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My 63 330 has that size rim and rear tire but I installed a later B body housing to get rid of the nutted housing. Tires are Mickey Thompson and are perfectly spaced in the wheelhouse. I used a 70 Charger 8 3/4.
IIRC the later housing added at least 1/2" width on each side.
Re: 64 Belvedere rear wheel advice [Re: GY3] #1649306
07/21/14 02:15 PM
07/21/14 02:15 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Use a thin spacer - problem solved.
Re: 64 Belvedere rear wheel advice [Re: max_maniac] #1649307
07/21/14 02:33 PM
07/21/14 02:33 PM
Big Island ,VA
Big Island ,VA
Spacers would just make it worse.....its already hitting the quarters on the inside. The 70 Charger rear might work. Any idea on what all year housings will work as in which ones are a tad shorter than the factory 64 Housing ?
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649308
07/21/14 02:36 PM
07/21/14 02:36 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
My bad as I read it too fast and thought it was hitting inner wheel housing. Can you bend in the wheel lip to get enough room or is that something you do not want to do?
Re: 64 Belvedere rear wheel advice [Re: max_maniac] #1649309
07/21/14 02:42 PM
07/21/14 02:42 PM
Big Island ,VA
Big Island ,VA
Its not the lip, its on up inside it. The car sits down over the tire.
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649310
07/21/14 03:29 PM
07/21/14 03:29 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
65 to IIRC 68 are the shortest. 69 up rears are wider.When I cut the Dana Ill cut it 1/2 inch shorter than my OE 65 housing thats now in my kids 62 300.He has 10 inch wide tires under it and has plenty of room.His other set of tires was about 10 1/2 wide and cleared.I have a 69 housing under my 65 and its wider than the 65 one.Rocky
Chrysler Firepower
Re: 64 Belvedere rear wheel advice [Re: therocks] #1649311
07/21/14 04:08 PM
07/21/14 04:08 PM
Big Island ,VA
Big Island ,VA
I'm not disputing you but if thats the case then how did the 70 Charger rear work in the other fellas car ?
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649312
07/21/14 04:30 PM
07/21/14 04:30 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
You want a 65 B-Body Housing
Re: 64 Belvedere rear wheel advice [Re: SSAAHemiFan] #1649313
07/21/14 05:04 PM
07/21/14 05:04 PM
Big Island ,VA
Big Island ,VA
Thats different than my 64 ?
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649314
07/21/14 07:24 PM
07/21/14 07:24 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Will changing the back spacing on your rims help ?
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649315
07/21/14 07:58 PM
07/21/14 07:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '64 B-body rear end is wider than pre-'71 B-body rear ends.
B-body overall widths drum-to-drum:
'64 = 60 7/8" (Exc.Max Wedge)
'65-'67= 59 1/2"
'68-'70= 60 1/8"
Re: 64 Belvedere rear wheel advice [Re: John_Kunkel] #1649316
07/21/14 09:59 PM
07/21/14 09:59 PM
Big Island ,VA
Big Island ,VA
Thanks John. Thats the kind of info I needed. Awesome !
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649317
07/21/14 10:07 PM
07/21/14 10:07 PM
Niles , Ohio
Niles , Ohio
JC the 70 will work but its wider.I have a 69R/T rear under the 65.Only reason I used it was because I bought it DtoD for 35 bucks and it had the large axles compared to the 65s.I can almost get 5 1/2 BS 10 inch wide rims under the 65.They are close to the spring.On the 65 rear they would hit.Rocky
Chrysler Firepower
Re: 64 Belvedere rear wheel advice [Re: therocks] #1649318
07/22/14 01:35 AM
07/22/14 01:35 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I had that same problem JC. I had my 30 x 9 Hoosier radial slicks on an 8" wheel and when I hit bumps on the road with a passenger in the car they would rub up on the inside of the 1/4 also. So right now I have my 30 x 9 tires on my 15 x 7" steelies. And it moved the tire in about an inch. They fit perfect now with about 3/4" on the inside at the spring and the same up in the 1/4 and they dont rub at all on the street. If it was a race car only I could get away with the 8" wheels but not driving on the street. The car is still hooking great on these wheels and they are working fine for me. But remember I have a rear from a 65 B-body in my 63 as I wanted to get away from the drums with the hub and nut on them. Ron
Re: 64 Belvedere rear wheel advice [Re: 383man] #1649319
07/22/14 01:58 PM
07/22/14 01:58 PM
Big Island ,VA
Big Island ,VA
I have an 8 3/4 from a Duster that I may try. I know its a little narrower.
Re: 64 Belvedere rear wheel advice [Re: JC Childress] #1649320
07/22/14 03:56 PM
07/22/14 03:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A-body standard width is quite a bit narrower at 57 1/8" overall, with typical BBP axles it's closer to 58"...might have a problem with tires rubbing the inner wheelhouse.
Re: 64 Belvedere rear wheel advice [Re: John_Kunkel] #1649321
07/22/14 08:04 PM
07/22/14 08:04 PM
NY
X
XXHEMI Offline
XXHEMI  Offline
X
NY
Wish I saw this last week!
I just ordered 8"steelies and 28x10 slicks for my 63.It does have a 69 8 3/4 in it. I hope they work?
Does anyone know of an adapter that allows the older dog dishes to work on the newer style wheel?
I would like to keep the Stock Appearing.
Re: 64 Belvedere rear wheel advice [Re: XXHEMI] #1649322
07/22/14 10:40 PM
07/22/14 10:40 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I epoxied a couple of later dog dishes inside a pair of the larger ones for use on my 15x8 Wheel Vintiques wheels.
Re: 64 Belvedere rear wheel advice [Re: GY3] #1649323
07/23/14 12:16 PM
07/23/14 12:16 PM
Big Island ,VA
Big Island ,VA
That looks pretty durn good.
