64 Belvedere rear wheel advice
#1649304
07/21/14 01:33 PM
07/21/14 01:33 PM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
I have a 64 Belvedere. Everything is stock in the suspension. I want to put 275/60 radials on and not have any problems. I have 15x8 rear wheels with 4.5 backspacing. The tires are rubbing the inner quarter panels. Any suggestions ? I thought that this size wheel was supposed to clear with a 275/60 tire.
J.C. Childress
(434) 665-9541
Re: 64 Belvedere rear wheel advice
[Re: max_maniac]
#1649307
07/21/14 02:33 PM
07/21/14 02:33 PM
JC Childress
Big Island ,VA
Spacers would just make it worse.....its already hitting the quarters on the inside. The 70 Charger rear might work. Any idea on what all year housings will work as in which ones are a tad shorter than the factory 64 Housing ?
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1649308
07/21/14 02:36 PM
07/21/14 02:36 PM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
My bad as I read it too fast and thought it was hitting inner wheel housing. Can you bend in the wheel lip to get enough room or is that something you do not want to do?
[Re: max_maniac]
#1649309
07/21/14 02:42 PM
07/21/14 02:42 PM
JC Childress
Big Island ,VA
Its not the lip, its on up inside it. The car sits down over the tire.
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1649310
07/21/14 03:29 PM
07/21/14 03:29 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
65 to IIRC 68 are the shortest. 69 up rears are wider.When I cut the Dana Ill cut it 1/2 inch shorter than my OE 65 housing thats now in my kids 62 300.He has 10 inch wide tires under it and has plenty of room.His other set of tires was about 10 1/2 wide and cleared.I have a 69 housing under my 65 and its wider than the 65 one.Rocky
Chrysler Firepower
[Re: therocks]
#1649311
07/21/14 04:08 PM
07/21/14 04:08 PM
JC Childress
Big Island ,VA
I'm not disputing you but if thats the case then how did the 70 Charger rear work in the other fellas car ?
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1649315
07/21/14 07:58 PM
07/21/14 07:58 PM
Posts: 25,844 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The '64 B-body rear end is wider than pre-'71 B-body rear ends.
B-body overall widths drum-to-drum:
'64 = 60 7/8" (Exc.Max Wedge) '65-'67= 59 1/2" '68-'70= 60 1/8"
[Re: JC Childress]
#1649317
07/21/14 10:07 PM
07/21/14 10:07 PM
therocks
Niles , Ohio
JC the 70 will work but its wider.I have a 69R/T rear under the 65.Only reason I used it was because I bought it DtoD for 35 bucks and it had the large axles compared to the 65s.I can almost get 5 1/2 BS 10 inch wide rims under the 65.They are close to the spring.On the 65 rear they would hit.Rocky
Chrysler Firepower
[Re: 383man]
#1649319
07/22/14 01:58 PM
07/22/14 01:58 PM
JC Childress
Big Island ,VA
I have an 8 3/4 from a Duster that I may try. I know its a little narrower.
J.C. Childress
(434) 665-9541
[Re: JC Childress]
#1649320
07/22/14 03:56 PM
07/22/14 03:56 PM
John_Kunkel
Rio Linda, CA
A-body standard width is quite a bit narrower at 57 1/8" overall, with typical BBP axles it's closer to 58"...might have a problem with tires rubbing the inner wheelhouse.
[Re: XXHEMI]
#1649322
07/22/14 10:40 PM
07/22/14 10:40 PM
Posts: 4,684 Wichita
GY3
Wichita
Wish I saw this last week!
Does anyone know of an adapter that allows the older dog dishes to work on the newer style wheel?
I epoxied a couple of later dog dishes inside a pair of the larger ones for use on my 15x8 Wheel Vintiques wheels.
