Need help with SW 960 tach #1648356
07/19/14 09:39 PM
07/19/14 09:39 PM
Maryland
ro23_j Offline OP
ro23_j  Offline OP
Maryland
I have an old Stewart Warner 960AA tach (does not require a sending unit) that I am trying to get to work with a Prestolite black box ignition system.
I do not have any wiring instructions so I contacted SW to find out if they could help but they no longer have any installation instructions for the old products. They did send me a drawing but the terminals are not labeled. The tach has three terminals on the back, one for coil, power and ground that were labeled when I got it. I hooked it up according to the labels but got nothing. Tried switching the coil signal wire from (-) to (+) with no difference.
Before I send it out for repair, I would like to try and find a copy of the installation instructions for this model, so if anyone would happen to have them, I would like to get a copy. Also, if anyone has used one of these with a transistor ignition, any advice would be appreciated.
Thanks,
Re: Need help with SW 960 tach [Re: ro23_j] #1648357
07/19/14 10:37 PM
07/19/14 10:37 PM
You might Google a request for those instructions & see what pops up. Do ya feel lucky
Re: Need help with SW 960 tach [Re: RapidRobert] #1648358
07/20/14 10:30 PM
07/20/14 10:30 PM
Maryland
ro23_j Offline OP
ro23_j  Offline OP
Maryland
I tried that before I posted here but got nothing. There appears to be a lot of info for a similar SW model that was used in the Yenko cars, but that one uses a sending unit.
Thanks,
