what holds steering wheel shaft in place? #1645680
07/12/14 02:28 PM
07/12/14 02:28 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
69 B body 4 speed. Shaft that steering wheel attaches to moves in and out of column. What's broken?
Re: what holds steering wheel shaft in place? [Re: frank] #1645681
07/12/14 03:04 PM
07/12/14 03:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are plastic shear "rivets" that allow the steering wheel shaft to collapse in the event of a collision, the rivets have sheared off.
Some popular fixes involve replacing the rivets with hardware store plastic screws or bonding the upper/lower shafts together.
The factory offered a kit to bond the shafts together but any that might be left will have the adhesive dried up by now.
Re: what holds steering wheel shaft in place? [Re: John_Kunkel] #1645682
07/12/14 03:28 PM
07/12/14 03:28 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
So the fix is to remove the shaft, take everything apart, replace the plastic rivets, re assemble and reinstall
Re: what holds steering wheel shaft in place? [Re: frank] #1645683
07/12/14 03:34 PM
07/12/14 03:34 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
I reset mine to the proper dimension(length)and used brass screws...
Re: what holds steering wheel shaft in place? [Re: RSNOMO] #1645684
07/12/14 03:46 PM
07/12/14 03:46 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
when i converted mine to manual steering i set the length then put 2 small tack welds where the 2 segments join, they will fail in a collision allowing the column to collapse.
Re: what holds steering wheel shaft in place? [Re: frank] #1645685
07/12/14 07:31 PM
07/12/14 07:31 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
First the bearing is held to the steering shaft by a c clip, the bearing is held to the steering column by a bearing retainer, and the bearing retainer is screwed the column shaft by j type bolts.
If you pull the steering wheel you will see some small nuts attached to a bolt. Position these so the steering shaft doesn't move and tighten up the nuts.
Never pull on a steering column when moving a car. DAMHIK!
