A518- A500 Transmission control question #1643145
07/07/14 12:10 AM
07/07/14 12:10 AM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
I have a 1990 B350 Van with a 360 and 4 speed auto,(Not sure what model as of yet.) I had a problem with the ECM and changed it out with one from a 1990 Dodge W250 with a 4 speed Manual Transmission.. The van started right up and shifted fine, just wouldn't go into overdrive. So I took it for a drive yesterday,I have no reverse, and it wont coast in neutral.. Would this have anything to do with changing the ECM? As I said the one I replaced it with was from a Manual Trans Truck, so Im figuring it has no transmission control capability since it was from a manual truck.. It may be a coincidence that it happened not long after changing ECM.. What are your thoughts? Thanks
Re: A518- A500 Transmission control question [Re: EV2RUNNER] #1643146
07/07/14 12:33 AM
07/07/14 12:33 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, a manual trans ECU will not play well with an auto that needs the ECU to control the OD and torque converter lockup.
Don't be the exception.
Re: A518- A500 Transmission control question [Re: Supercuda] #1643147
07/07/14 02:47 AM
07/07/14 02:47 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
On a 1990 all the computer controls is overdrive and possibly lockup. 1st-3rd and reverse are still hydraulically controlled, exactly the same as a 727 or 904. It would run the 3 gears forward and reverse with no computer at all. You have bigger problems.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: A518- A500 Transmission control question [Re: herkamer] #1643148
07/07/14 02:59 AM
07/07/14 02:59 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Might be in limp mode because of the mismatched ecm.
Re: A518- A500 Transmission control question [Re: stumpy] #1643149
07/07/14 09:55 AM
07/07/14 09:55 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can order the correct ECM from Solo Electronics in Florida.
Re: A518- A500 Transmission control question [Re: EV2RUNNER] #1643150
07/07/14 05:02 PM
07/07/14 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does it try to drive forward in Neutral and lurch forward in Park?
Re: A518- A500 Transmission control question [Re: EV2RUNNER] #1643151
07/07/14 10:51 PM
07/07/14 10:51 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
1990 is not computer controlled with the exception of OD and the converter clutch.
Unplug the connector at the trans and see if you still lose reverse. If so, its in the trans.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: A518- A500 Transmission control question [Re: John_Kunkel] #1643152
07/07/14 11:36 PM
07/07/14 11:36 PM
St.Clairsville Ohio
St.Clairsville Ohio
Yes! That's exactly what it's doing John
Re: A518- A500 Transmission control question [Re: zzyzxpat] #1643153
07/07/14 11:39 PM
07/07/14 11:39 PM
St.Clairsville Ohio
St.Clairsville Ohio
Pat
Yea I tried that Pat,Still same..Im afraid it was just coincidence, and tranny may need rebuild
Re: A518- A500 Transmission control question [Re: zzyzxpat] #1643154
07/08/14 12:28 AM
07/08/14 12:28 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Pat
It really should not make any difference about the overdrive/lockup connector being unplugged or not as the trans will still work normal just no overdrive or lockup if unhooked.
But from what the OP just said and from what John asked him it sounds like welded clutches if it lurches in Park and does not have reverse. If clutches are welded trying to go forward it would just be in drive and reverse when in reverse and not move. I believe thats what John is going to tell him. Ron
Re: A518- A500 Transmission control question [Re: 383man] #1643155
07/08/14 12:37 AM
07/08/14 12:37 AM
St.Clairsville Ohio
St.Clairsville Ohio
That's kinda what I was figuring, but I knew these had some electronics to them I was hoping maybe I would get lucky! Thanks for the info
Re: A518- A500 Transmission control question [Re: EV2RUNNER] #1643156
07/08/14 04:03 PM
07/08/14 04:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's likely that the Bellville spring in the rear clutch has failed and allowed the piston to pop out of its bore and jam the clutch pack together.
