Re: A518- A500 Transmission control question
[Re: EV2RUNNER]
#1643146
07/07/14 12:33 AM
07/07/14 12:33 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Yes, a manual trans ECU will not play well with an auto that needs the ECU to control the OD and torque converter lockup.
[Re: Supercuda]
#1643147
07/07/14 02:47 AM
07/07/14 02:47 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
On a 1990 all the computer controls is overdrive and possibly lockup. 1st-3rd and reverse are still hydraulically controlled, exactly the same as a 727 or 904. It would run the 3 gears forward and reverse with no computer at all. You have bigger problems.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: stumpy]
#1643149
07/07/14 09:55 AM
07/07/14 09:55 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
You can order the correct ECM from Solo Electronics in Florida.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: EV2RUNNER]
#1643150
07/07/14 05:02 PM
07/07/14 05:02 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does it try to drive forward in Neutral and lurch forward in Park?
[Re: EV2RUNNER]
#1643151
07/07/14 10:51 PM
07/07/14 10:51 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
1990 is not computer controlled with the exception of OD and the converter clutch. Unplug the connector at the trans and see if you still lose reverse. If so, its in the trans.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
[Re: zzyzxpat]
#1643153
07/07/14 11:39 PM
07/07/14 11:39 PM
Posts: 433 St.Clairsville Ohio
EV2RUNNER
St.Clairsville Ohio
Pat
Yea I tried that Pat,Still same..Im afraid it was just coincidence, and tranny may need rebuild
[Re: EV2RUNNER]
#1643156
07/08/14 04:03 PM
07/08/14 04:03 PM
John_Kunkel
Rio Linda, CA
It's likely that the Bellville spring in the rear clutch has failed and allowed the piston to pop out of its bore and jam the clutch pack together.
